Ana içeriğe geç
CR-10S Pro Noctua Fan Upgrade
Neye ihtiyacın var
  1. CR-10S Pro Noctua Fan Upgrade, Included kit parts: adım 1, 2 resimden 1. CR-10S Pro Noctua Fan Upgrade, Included kit parts: adım 1, 2 resimden 2.
    • Labeled bags are used in the following steps
    • Hardware
    • Power Supply Fan (Step 4)
    • Rear Case Exhaust Fan(Step 5)
    • Control Board Fan Assembly (Step 6)
  2. CR-10S Pro Noctua Fan Upgrade, Bottom cover and PSU mounting screws: adım 2, 3 resimden 1. CR-10S Pro Noctua Fan Upgrade, Bottom cover and PSU mounting screws: adım 2, 3 resimden 2. CR-10S Pro Noctua Fan Upgrade, Bottom cover and PSU mounting screws: adım 2, 3 resimden 3.
    • Using a #1 Phillips screwdriver, remove the 11 screws on the bottom and 2 screws on each side for a total of 15
    • Next, remove the bottom cover
    • With the bottom cover removed, turn the printer sideways and remove the power supple unit (PSU) screws while holding the PSU in place ribbon cable side up
  3. CR-10S Pro Noctua Fan Upgrade, Removing the PSU Fan: adım 3, 3 resimden 1. CR-10S Pro Noctua Fan Upgrade, Removing the PSU Fan: adım 3, 3 resimden 2. CR-10S Pro Noctua Fan Upgrade, Removing the PSU Fan: adım 3, 3 resimden 3.
    • Remove the 6 PSU screws securing the cover (circled in blue)
    • Next, remove the 2 screws securing the original 4020 Fan (circled in red)
  4. CR-10S Pro Noctua Fan Upgrade, Installing PSU Fan: adım 4, 3 resimden 1. CR-10S Pro Noctua Fan Upgrade, Installing PSU Fan: adım 4, 3 resimden 2. CR-10S Pro Noctua Fan Upgrade, Installing PSU Fan: adım 4, 3 resimden 3.
    • Unplug the original fan cable
    • Original fan cable is glued down. Gently, pull up on the cable to remove after you unplug the connector
    • Route the new fan cable under the white wires
    • Plug in new fan cable
    • Mount fan with Self tapping screws included in the kit
    • Pay attention to the fan orientation and wire placement
    • Follow step 2 in reverse for reinstallation of the PSU cover
  5. CR-10S Pro Noctua Fan Upgrade: adım 5, 2 resimden 1. CR-10S Pro Noctua Fan Upgrade: adım 5, 2 resimden 2.
    • Remove M3 Screw holding stock fan and replace the fan with the new 4010 fan using the included M3x12 socket head screws
    • Fork connector for the red(+V) and black(-V) wire are mounted to there respect screw terminals on the PSU
  6. CR-10S Pro Noctua Fan Upgrade, Control Fan Assembly Installation: adım 6, 3 resimden 1. CR-10S Pro Noctua Fan Upgrade, Control Fan Assembly Installation: adım 6, 3 resimden 2. CR-10S Pro Noctua Fan Upgrade, Control Fan Assembly Installation: adım 6, 3 resimden 3.
    • Remove original motherboard mounting screws and save for future step
    • Included Nylon standoffs replace control board mounting screws
    • Make sure SD card slot and USB cable slot maintain alignment with the frame cutouts
    • Place the Control Fan Assembly as shown
    • Use the previously remove M3 screws to secure the 3D printed fan mount to the standoffs.
    • Plug in Fan adapter cable
Sonuç
AJ Pereira
2.707 İtibar
16 adet Kılavuz yazıldı
Ekip
Tiny Machines 3D Tiny Machines 3D üyesi
Community
5 Üyeler
41 adet Kılavuz yazıldı
8Kılavuz Yorumları
So where do you get the parts kit? I don’t see that in the post anywhere.
Tim Gray - Yanıt
I would like to know where the parts kit can be purchased as well, either that or a list of part numbers.
lauriecrabb - Yanıt
You can email us at support@tinymachines3d.com to order a kit
AJ Pereira -
Does this apply to v2
Jack Gillson - Yanıt
Yes, it does apply to the CR10S Pro V2 as well
AJ Pereira -
How is the fan solved in step 5, the source is 24v and the fan is only 12v???
Tomáš Lašek - Yanıt
A buck converter is used to step down the voltage to 12V
AJ Pereira -
Can this kit be used also for CR-X ? As they have mainly same components. THanks in advance.
Sancay Akbulut - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 31
Son 30 gün: 87
Her zaman: 7,749
