Ana içeriğe geç
CR10S Pro V1 MOSFET Upgrade
Neye ihtiyacın var
  1. CR10S Pro V1  MOSFET Upgrade, MOSFET Wiring and installation: adım 1, 3 resimden 1. CR10S Pro V1  MOSFET Upgrade, MOSFET Wiring and installation: adım 1, 3 resimden 2. CR10S Pro V1  MOSFET Upgrade, MOSFET Wiring and installation: adım 1, 3 resimden 3.
    • The used mounting holes are boxed in green
    • The red cable from the bed goes the Vout terminal boxed in red on the picture.
    • The black cable from the bed is moved from the -V screw terminal of the Power supply unit(PSU) to the +V screw terminal on the PSU
    • The red cable used to connect between the PSU +V and the SSR will now go to the screw terminal boxed in orange
    • New black cable will connect between the -V on the PSU and the V- on the MOSFET box in Black.
    • New jst pigtail connector cable will connect to the connector on the MOSFET boxed in blue and to the Control Board Bed positive and negative screw terminal for the bed heater
  2. CR10S Pro V1  MOSFET Upgrade, Bed heater Signal connection: adım 2, 1 resimden 1.
    • The MOSFET Signal connection Connects to the Bed Heater port Blue
    can you link the kit for me?
    eckleybrian - Yanıt
Sonuç
Bir başkası bu kılavuzu tamamladı.
AJ Pereira
2.707 İtibar
16 adet Kılavuz yazıldı
Ekip
Tiny Machines 3D Tiny Machines 3D üyesi
Community
5 Üyeler
41 adet Kılavuz yazıldı
2 Yorum
Hi AJ, thx a lot for your help! Klaus from TOP CLASSIC CARS LLC
Klaus Hackbarth - Yanıt
Hi!
With a delay of 3 years... Thanks for the instructions! Would this be valid for the Creality CR 10s PRO v2? I got this model in 2019... it remained stuck on my mind that it was advertised back then as a v2, that's why i wrote it like that. But now I'm not sure as I found this component as a standard in cr10s pro v2 and mine had a SSR module for the heated bed. Well... the SSR module has reached it's time I guess and broke. I compared the mainboards ( mine vs the one in the picture) and I'm a bit confused as I cannot distinguish the marks on the big black square chip and also I have no idea if it matters anyway.
I hope someone can help me, as I don't want to give up on this printer.
Thanks!
Dragos
Dragos - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 18
Son 30 gün: 69
Her zaman: 2,711
