Ana içeriğe geç
CRKD NEO S CK24NS Button Replacement
Neye ihtiyacın var
  1. CRKD NEO S CK24NS Button Replacement, Motherboard: adım 1, 1 resimden 1.
    • Turn the CRKD NEO S CK24NS upside down with the front-facing buttons facing downward.
  2. CRKD NEO S CK24NS Button Replacement: adım 2, 3 resimden 1. CRKD NEO S CK24NS Button Replacement: adım 2, 3 resimden 2. CRKD NEO S CK24NS Button Replacement: adım 2, 3 resimden 3.
    • Use a 1.5 mm Hex screwdriver to remove the eight 1.5 mm Hex screws from the back of the controller.
    • Carefully lift off the back panel and set it aside.
  3. CRKD NEO S CK24NS Button Replacement: adım 3, 3 resimden 1. CRKD NEO S CK24NS Button Replacement: adım 3, 3 resimden 2. CRKD NEO S CK24NS Button Replacement: adım 3, 3 resimden 3.
    • Remove the four 2.5 mm screws holding the motherboard in place using a Phillips #0 screwdriver.
    • Take out the white plastic pieces connected to the motherboard with tweezers.
    • Gently lift the motherboard and set it aside.
    • If the small red plastic piece next to the audio jack falls out, don’t worry. You can pop it back into place during reassembly.
  4. CRKD NEO S CK24NS Button Replacement, Button: adım 4, 2 resimden 1. CRKD NEO S CK24NS Button Replacement, Button: adım 4, 2 resimden 2.
    • Depending on the button(s) you want to replace, lift them out with a pair of tweezers and put the new buttons in.
    • Make sure the controller is facedown because the buttons will fall out.
Sonuç
Kailey Sillitoe
295 İtibar
2 adet Kılavuz yazıldı
Ekip
Utah Tech University, Team 1-1, Crenshaw Fall 2024 Utah Tech University, Team 1-1, Crenshaw Fall 2024 üyesi
UTAHTECH-CRENSHAW-F24S1G1
3 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 16
Her zaman: 268
