Ana içeriğe geç
Calculator is Stuck While Graphing
  1. Calculator is Stuck While Graphing, Calculator is Stuck While Graphing: adım 1, 1 resimden 1.
    • To cancel the graphing process, press the "ON" button.
  2. Calculator is Stuck While Graphing: adım 2, 3 resimden 1. Calculator is Stuck While Graphing: adım 2, 3 resimden 2. Calculator is Stuck While Graphing: adım 2, 3 resimden 3.
    • Go to "Zoom." Navigate to and highlight "ZoomFit" then press "Enter." Doing so will automatically set your graphing window to the most appropriate dimensions.
  3. Calculator is Stuck While Graphing: adım 3, 1 resimden 1.
    • If you are graphing complex equations, multiple equations, or a combination of the two, it may take anywhere from 1 minute to 5 minutes to graph.
    • The bar on the top right corner indicates the calculator is graphing.
  4. Calculator is Stuck While Graphing: adım 4, 2 resimden 1. Calculator is Stuck While Graphing: adım 4, 2 resimden 2.
    • If you feel that your graph is taking too long, you can change the step resolution to a bigger number. To do so, press "Window" and change "Xres" to a value between 1 and 8. A bigger Xres value will graph more quickly.
Sonuç
It is always a good idea to make sure your graph will display a good window.
John Baek
31 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 7-52, Forte Fall 2012 Cal Poly, Team 7-52, Forte Fall 2012 üyesi
CPSU-FORTE-F12S7G52
5 Üyeler
14 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 9
Son 30 gün: 19
Her zaman: 2,025
