Ana içeriğe geç
Cambridge Audio A3i Motherboard Replacement
Neye ihtiyacın var
  1. Cambridge Audio A3i Motherboard Replacement, Case: adım 1, 1 resimden 1.
    • Remove 2 screws from each side of the amplifier.
  2. Cambridge Audio A3i Motherboard Replacement: adım 2, 1 resimden 1.
    • Remove 2 screws on rear of device. Slide top cover up and back from main case.
  3. Cambridge Audio A3i Motherboard Replacement: adım 3, 2 resimden 1. Cambridge Audio A3i Motherboard Replacement: adım 3, 2 resimden 2.
    • Remove 3 screws on bottom of case.
    • Remove 13 screws on rear panel.
    • Do not move the rear panel too far, as the power cord is still connected.
  4. Cambridge Audio A3i Motherboard Replacement: adım 4, 1 resimden 1.
    • Using a pair of pliers, squeeze the retainer for the power cord as shown and pull it toward the external side the panel.
    • It may require some wiggling, but it should slip out of the hole and then off of the cord.
  5. Cambridge Audio A3i Motherboard Replacement, Motherboard: adım 5, 1 resimden 1.
    • Remove 2 screws from each side of the heatsink. These must be accessed from directly above the device.
    • Remove the green grounding wire from the mounting screw.
  6. Cambridge Audio A3i Motherboard Replacement: adım 6, 1 resimden 1.
    • With the amplifier on it's side, remove the 4 screws that hold the motherboard frame to the main case.
    • Be sure to hold the motherboard with one hand while removing the mount screws.
  7. Cambridge Audio A3i Motherboard Replacement: adım 7, 2 resimden 1. Cambridge Audio A3i Motherboard Replacement: adım 7, 2 resimden 2.
    • Unscrew ground wire from main case.
    • De solder 4 wires coming from transformer.
    • The motherboard can now be lifted from the case. Any part that needs to be removed from it can be de-soldered.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Colby
338 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 28-36, Regan Spring 2010 Cal Poly, Team 28-36, Regan Spring 2010 üyesi
CPSU-REGAN-S10S28G36
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 7
Son 30 gün: 29
Her zaman: 6,623
