Ana içeriğe geç
Cambridge SoundWorks OontZ Angle Plus Motherboard Replacement
Neye ihtiyacın var
  1. Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement, Lower Casing: adım 1, 2 resimden 1. Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement, Lower Casing: adım 1, 2 resimden 2.
    • Pull back the six screw covers on the bottom of the device.
    • Starting from the screw covers, peel the casing away from the bottom plate.
    FixBot'a Sor
    Yorum Ekle
  2. Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement, Battery: adım 2, 1 resimden 1.
    • Unscrew the five 11.5mm Phillips screws on the bottom plate.
    FixBot'a Sor
    Yorum Ekle
  3. Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement: adım 3, 1 resimden 1.
    • Carefully pull apart the bottom plate and the top plate, using the blue plastic opening tool.
    FixBot'a Sor
    Yorum Ekle
  4. Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement: adım 4, 1 resimden 1.
    • Once the bottom plate and the top plate are separated, slowly pull the back plate away from the top plate.
    • There are wires connected to both plates so do this step with care.
    FixBot'a Sor
    Yorum Ekle
  5. Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement: adım 5, 1 resimden 1.
    • Unscrew the two 10 mm Phillips screws on the brace holding down the battery.
    • Remove the brace that holds the battery in place.
    FixBot'a Sor
    Yorum Ekle
  6. Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement: adım 6, 1 resimden 1.
    • Separate the battery from the bottom plate and set the bottom plate aside.
    FixBot'a Sor
    Yorum Ekle
  7. Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement: adım 7, 1 resimden 1.
    • With some force, push the motherboard straight in toward the center of the device.
    FixBot'a Sor
    Yorum Ekle
  8. Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement: adım 8, 1 resimden 1.
    • Pull the motherboard straight out of the device.
    • There is some adhesive on the motherboard that holds it in place. This make the motherboard fit in the groove rather tight.
    FixBot'a Sor
    Yorum Ekle
  9. Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement: adım 9, 1 resimden 1.
    • Desolder the wires that connect the battery to the motherboard, negative (black wire) and positive (red wire).
    FixBot'a Sor
    Yorum Ekle
  10. Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement, Motherboard: adım 10, 1 resimden 1.
    • Unplug the wires that connect the speakers to the motherboard.
    FixBot'a Sor
    Yorum Ekle
  11. Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement: adım 11, 1 resimden 1.
    • Unplug the thin white cable connected to the buttons.
    FixBot'a Sor
    Yorum Ekle
  12. Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement: adım 12, 2 resimden 1. Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement: adım 12, 2 resimden 2.
    • Desolder the wires that connect the LED to the motherboard.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Farshad Mohebban
524 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-1, Nance Spring 2016 USF Tampa, Team 1-1, Nance Spring 2016 üyesi
USFT-NANCE-S16S1G1
4 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 22
Her zaman: 2,096
