Ana içeriğe geç
Cambridge SoundWorks OontZ Angle Plus Speaker Grill Replacement
Neye ihtiyacın var
  1. Cambridge SoundWorks OontZ Angle Plus Speaker Grill Replacement, Rubber Casing: adım 1, 1 resimden 1.
    • Remove the six screw covers from the bottom of the device.
  2. Cambridge SoundWorks OontZ Angle Plus Speaker Grill Replacement: adım 2, 1 resimden 1.
    • Starting from the screw covers, remove the front and back casing of the device.
  3. Cambridge SoundWorks OontZ Angle Plus Speaker Grill Replacement: adım 3, 1 resimden 1.
    • Carefully pull off the casing covering the ends.
  4. Cambridge SoundWorks OontZ Angle Plus Speaker Grill Replacement: adım 4, 1 resimden 1.
    • Slowly remove the casing from the top of the device.
  5. Cambridge SoundWorks OontZ Angle Plus Speaker Grill Replacement, Speaker Grill: adım 5, 1 resimden 1.
    • Unscrew the five 11.5mm Phillips screws from the bottom plate.
  6. Cambridge SoundWorks OontZ Angle Plus Speaker Grill Replacement: adım 6, 1 resimden 1.
    • Carefully pull apart the bottom and top plates, using the blue plastic opening tool.
  7. Cambridge SoundWorks OontZ Angle Plus Speaker Grill Replacement: adım 7, 1 resimden 1.
    • Once the plates are separated, slowly pull the bottom plate away from the top plate.
    • There are wires connected to both plates, so be cautious while doing this step.
  8. Cambridge SoundWorks OontZ Angle Plus Speaker Grill Replacement: adım 8, 1 resimden 1.
    • Use the metal spudger to bend the three bendable clamps on the ends of the speaker cover.
    • Beware, the bending process requires patience and extra time.
  9. Cambridge SoundWorks OontZ Angle Plus Speaker Grill Replacement: adım 9, 1 resimden 1.
    • Next, use the metal spudger to bend the four bendable clamps on the bottom of the speaker cover.
    • This step also requires some time and patience.
  10. Cambridge SoundWorks OontZ Angle Plus Speaker Grill Replacement: adım 10, 2 resimden 1. Cambridge SoundWorks OontZ Angle Plus Speaker Grill Replacement: adım 10, 2 resimden 2.
    • Finally, bend the speaker cover upward and it will slide out.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Farshad Mohebban
524 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-1, Nance Spring 2016 USF Tampa, Team 1-1, Nance Spring 2016 üyesi
USFT-NANCE-S16S1G1
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 9
Her zaman: 1,017
