Giriş
Use this guide to replace the damaged or broken speaker cover of your Cambridge SoundWorks OontZ Angle Plus Speaker. The detailed steps will guide you if you are planning to customize your speaker and change the color of the cover. This is a relatively quick and easy replacement process.
Neye ihtiyacın var
Bir başkası bu kılavuzu tamamladı.
