Ana içeriğe geç
Cambridge SoundWorks OontZ Angle Plus Speakers Replacement
Neye ihtiyacın var
  1. Cambridge SoundWorks OontZ Angle Plus Speakers Replacement, Rubber Casing: adım 1, 1 resimden 1.
    • Remove the six screw covers from the bottom of the device.
  2. Cambridge SoundWorks OontZ Angle Plus Speakers Replacement: adım 2, 1 resimden 1.
    • Starting from the screw covers, remove the front and back casing of the device.
  3. Cambridge SoundWorks OontZ Angle Plus Speakers Replacement: adım 3, 1 resimden 1.
    • Carefully pull off the casing covering the ends.
  4. Cambridge SoundWorks OontZ Angle Plus Speakers Replacement: adım 4, 1 resimden 1.
    • Slowly remove the casing from the top of the device.
  5. Cambridge SoundWorks OontZ Angle Plus Speakers Replacement, Speaker Grill: adım 5, 1 resimden 1.
    • Unscrew the five 11.5mm Phillips screws from the bottom plate.
  6. Cambridge SoundWorks OontZ Angle Plus Speakers Replacement: adım 6, 1 resimden 1.
    • Carefully pull apart the bottom and top plates, using the blue plastic opening tool.
  7. Cambridge SoundWorks OontZ Angle Plus Speakers Replacement: adım 7, 1 resimden 1.
    • Once the plates are separated, slowly pull the bottom plate away from the top plate.
    • There are wires connected to both plates, so be cautious while doing this step.
  8. Cambridge SoundWorks OontZ Angle Plus Speakers Replacement: adım 8, 1 resimden 1.
    • Use the metal spudger to bend the three bendable clamps on the ends of the speaker cover.
    • Beware, the bending process requires patience and extra time.
  9. Cambridge SoundWorks OontZ Angle Plus Speakers Replacement: adım 9, 1 resimden 1.
    • Next, use the metal spudger to bend the four bendable clamps on the bottom of the speaker cover.
    • This step also requires some time and patience.
  10. Cambridge SoundWorks OontZ Angle Plus Speakers Replacement: adım 10, 2 resimden 1. Cambridge SoundWorks OontZ Angle Plus Speakers Replacement: adım 10, 2 resimden 2.
    • Finally, bend the speaker cover upward and it will slide out.
  11. Cambridge SoundWorks OontZ Angle Plus Speakers Replacement, Speakers: adım 11, 1 resimden 1.
    • With some force, push the motherboard straight in toward the center of the device.
  12. Cambridge SoundWorks OontZ Angle Plus Speakers Replacement: adım 12, 1 resimden 1.
    • Pull the motherboard straight out of the device.
    • There is some adhesive on the motherboard that holds it in place. This makes the motherboard fit in the groove rather tight.
  13. Cambridge SoundWorks OontZ Angle Plus Speakers Replacement: adım 13, 1 resimden 1.
    • Unplug the speaker's connector from the motherboard.
  14. Cambridge SoundWorks OontZ Angle Plus Speakers Replacement: adım 14, 1 resimden 1.
    • Unscrew the eight screws holding the speakers in place.
  15. Cambridge SoundWorks OontZ Angle Plus Speakers Replacement: adım 15, 1 resimden 1.
    • Desolder the the wires connected to the back side of both speakers.
  16. Cambridge SoundWorks OontZ Angle Plus Speakers Replacement: adım 16, 1 resimden 1.
    • Carefully push the speakers out one at a time.
Sonuç
David Rice
161 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 1-1, Nance Spring 2016 USF Tampa, Team 1-1, Nance Spring 2016 üyesi
USFT-NANCE-S16S1G1
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 4
Her zaman: 1,891
