Ana içeriğe geç
Campbell Hausfeld FP204800 Check Valve Replacement
Neye ihtiyacın var
  1. Campbell Hausfeld FP204800 Check Valve Replacement, Remove Shroud Screws: adım 1, 3 resimden 1. Campbell Hausfeld FP204800 Check Valve Replacement, Remove Shroud Screws: adım 1, 3 resimden 2. Campbell Hausfeld FP204800 Check Valve Replacement, Remove Shroud Screws: adım 1, 3 resimden 3.
    • Unscrew the four 1cm long shroud screws using a 6mm Allen Wrench.
  2. Campbell Hausfeld FP204800 Check Valve Replacement, Remove Shroud: adım 2, 2 resimden 1. Campbell Hausfeld FP204800 Check Valve Replacement, Remove Shroud: adım 2, 2 resimden 2.
    • Remove the plastic shroud from the compressor.
    • Do not pull the shroud too far from the compressor. You could damage the on/off switch wiring.
  3. Campbell Hausfeld FP204800 Check Valve Replacement, Remove The Wiring From the Pressure Switch to the On/Off Switch: adım 3, 1 resimden 1.
    • Gently pull the wire attached from the pressure switch to the on/off switch.
    • It should come off the pressure switch with ease.
    • Make sure you are pulling the correct wire. The pressure switch could be in a different configuration on your compressor than in the picture.
  4. Campbell Hausfeld FP204800 Check Valve Replacement, Remove the On/Off Switch Wiring: adım 4, 1 resimden 1.
    • Gently pull the wire connected from the on/off switch to the motor of the compressor.
    • It should be the only wire keeping the shroud from being lifted from the compressor.
  5. Campbell Hausfeld FP204800 Check Valve Replacement, Unscrew Exhaust Tube: adım 5, 1 resimden 1.
    • Unscrew the exhaust tube from the check valve using a Smart Wrench.
  6. Campbell Hausfeld FP204800 Check Valve Replacement, Unscrew Check Valve: adım 6, 1 resimden 1.
    • Unscrew the check valve by twisting it counter-clockwise using a Smart Wrench.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Caleb Davies
528 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 14-29, Maness Fall 2014 Cal Poly, Team 14-29, Maness Fall 2014 üyesi
CPSU-MANESS-F14S14G29
4 Üyeler
7 adet Kılavuz yazıldı
2 Yorum
I never thought that it will be that much easy. I was looking for this kind of guide and thanks to ifixit and author of this guide I have successfully did the check valve replacement. Thanks for sharing this.
http://zahroofvalves.com
Rodney A. Olsen - Yanıt
1. How do you know if it’s the pressure switch that’s bad?
2. What do ya do when they say the parts are discontinued??
Jennifer Epps - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 18
Her zaman: 1,360
