Ana içeriğe geç
Campbell Hausfeld FP204800 On/Off Switch Replacement
Neye ihtiyacın var
  1. Campbell Hausfeld FP204800 On/Off Switch Replacement, Remove Shroud Screws: adım 1, 3 resimden 1. Campbell Hausfeld FP204800 On/Off Switch Replacement, Remove Shroud Screws: adım 1, 3 resimden 2. Campbell Hausfeld FP204800 On/Off Switch Replacement, Remove Shroud Screws: adım 1, 3 resimden 3.
    • Unscrew the four 1cm long shroud screws using a 6mm Allen Wrench.
  2. Campbell Hausfeld FP204800 On/Off Switch Replacement, Remove Shroud: adım 2, 2 resimden 1. Campbell Hausfeld FP204800 On/Off Switch Replacement, Remove Shroud: adım 2, 2 resimden 2.
    • Remove the plastic shroud from the compressor.
    • Do not pull the shroud too far from the compressor. You could damage the on/off switch wiring.
  3. Campbell Hausfeld FP204800 On/Off Switch Replacement, Remove The Wiring From the Pressure Switch to the On/Off Switch: adım 3, 1 resimden 1.
    • Gently pull the wire attached from the pressure switch to the on/off switch.
    • It should come off the pressure switch with ease.
    • Make sure you are pulling the correct wire. The pressure switch could be in a different configuration on your compressor than in the picture.
  4. Campbell Hausfeld FP204800 On/Off Switch Replacement, Remove the On/Off Switch Wiring: adım 4, 1 resimden 1.
    • Gently pull the wire connected from the on/off switch to the motor of the compressor.
    • It should be the only wire keeping the shroud from being lifted from the compressor.
  5. Campbell Hausfeld FP204800 On/Off Switch Replacement, Configure the on/off switch for removal: adım 5, 2 resimden 1. Campbell Hausfeld FP204800 On/Off Switch Replacement, Configure the on/off switch for removal: adım 5, 2 resimden 2.
    • Twist the On/Off switch from the underside of the shroud.
    • Twist 90 degrees in any direction or until the on/off switch prongs are in a vertical position.
    • When the switch has reached the correct position, you will feel it "click" into place.
  6. Campbell Hausfeld FP204800 On/Off Switch Replacement, Remove the on/off switch: adım 6, 1 resimden 1.
    • Push the on/off switch from the underside of the shroud until it comes loose.
    • If the switch is not in the correct position highlighted in the previous step, it will not be easily removed and could damage the shroud.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Caleb Davies
528 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 14-29, Maness Fall 2014 Cal Poly, Team 14-29, Maness Fall 2014 üyesi
CPSU-MANESS-F14S14G29
4 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 14
Her zaman: 1,539
