Ana içeriğe geç
Campbell Hausfeld FP204800 Shroud Disassembly
Neye ihtiyacın var
  1. Campbell Hausfeld FP204800 Shroud Disassembly, Remove Shroud Screws: adım 1, 3 resimden 1. Campbell Hausfeld FP204800 Shroud Disassembly, Remove Shroud Screws: adım 1, 3 resimden 2. Campbell Hausfeld FP204800 Shroud Disassembly, Remove Shroud Screws: adım 1, 3 resimden 3.
    • Unscrew the four 1cm long shroud screws using a 6mm Allen Wrench.
  2. Campbell Hausfeld FP204800 Shroud Disassembly, Remove Shroud: adım 2, 2 resimden 1. Campbell Hausfeld FP204800 Shroud Disassembly, Remove Shroud: adım 2, 2 resimden 2.
    • Remove the plastic shroud from the compressor.
    • Do not pull the shroud too far from the compressor. You could damage the on/off switch wiring.
  3. Campbell Hausfeld FP204800 Shroud Disassembly, Remove The Wiring From the Pressure Switch to the On/Off Switch: adım 3, 1 resimden 1.
    • Gently pull the wire attached from the pressure switch to the on/off switch.
    • It should come off the pressure switch with ease.
    • Make sure you are pulling the correct wire. The pressure switch could be in a different configuration on your compressor than in the picture.
  4. Campbell Hausfeld FP204800 Shroud Disassembly, Remove the On/Off Switch Wiring: adım 4, 1 resimden 1.
    • Gently pull the wire connected from the on/off switch to the motor of the compressor.
    • It should be the only wire keeping the shroud from being lifted from the compressor.
Sonuç
Caleb Davies
528 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 14-29, Maness Fall 2014 Cal Poly, Team 14-29, Maness Fall 2014 üyesi
CPSU-MANESS-F14S14G29
4 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 7
Her zaman: 874
