Ana içeriğe geç
  1. The check engine light is on
    • The check engine light is on
  2. Hooking up the scan tool to find what is wrong The scan code is: p1391 which is cam shaft sensor code .
    • Hooking up the scan tool to find what is wrong
    • The scan code is: p1391 which is cam shaft sensor code .
  3. unplug the senor wire and get a tiny ranch and take the two pots off
    • unplug the senor wire and get a tiny ranch and take the two pots off
  4. MacBook Pil Tamir Setleri
    Başlangıç $69.99
    Buy Now
    Başlangıç $69.99
    Buy Now
  5. Pull the sensor straight off
    • Pull the sensor straight off
  6. buy a new sensor
    • buy a new sensor
  7. Put the sensor in the same direction that was pointed it when you take it off
    • Put the sensor in the same direction that was pointed it when you take it off
  8. Tighten the two pots so it does not slip and plug back it
    • Tighten the two pots so it does not slip and plug back it
  9. Get the scan tools and reset it so the check engine light goes off Turn the key to on position Select erase code
    • Get the scan tools and reset it so the check engine light goes off
    • Turn the key to on position
    • Select erase code
    • Hit yes
  10. the check engine light is off
    • the check engine light is off
Sonuç
adel_hydey
361 İtibar
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 0
Her zaman: 21
