Ana içeriğe geç
Canary CAN100USBK Audio and USB PCB Board Replacement
Neye ihtiyacın var
  1. Canary CAN100USBK Audio and USB PCB Board Replacement, Bottom Casing: adım 1, 2 resimden 1. Canary CAN100USBK Audio and USB PCB Board Replacement, Bottom Casing: adım 1, 2 resimden 2.
    • Grip the rubber ring with your fingers and pull up.
    • Rotate the Canary as you pull out one tab at a time.
  2. Canary CAN100USBK Audio and USB PCB Board Replacement: adım 2, 1 resimden 1.
    • Use your Phillips #0 screwdriver to remove the four 6mm screws.
  3. Canary CAN100USBK Audio and USB PCB Board Replacement: adım 3, 3 resimden 1. Canary CAN100USBK Audio and USB PCB Board Replacement: adım 3, 3 resimden 2. Canary CAN100USBK Audio and USB PCB Board Replacement: adım 3, 3 resimden 3.
    • Use the flat end of the spudger to carefully pry off the bottom casing.
    • Alternate pushing up on the left and right sides until the clips holding the case in are visible.
  4. Canary CAN100USBK Audio and USB PCB Board Replacement: adım 4, 2 resimden 1. Canary CAN100USBK Audio and USB PCB Board Replacement: adım 4, 2 resimden 2.
    • Do not yank the bottom off or you may damage the ribbon cable or the ZIF connector.
    • Carefully remove the bottom casing by gripping it on both sides and pulling straight up.
  5. Canary CAN100USBK Audio and USB PCB Board Replacement: adım 5, 2 resimden 1. Canary CAN100USBK Audio and USB PCB Board Replacement: adım 5, 2 resimden 2.
    • Use the pointed end of the spudger to flip up the small retaining flap on the ZIF (zero insertion force) connector.
    • Pull the ribbon cable out towards the device.
  6. Canary CAN100USBK Audio and USB PCB Board Replacement, Ethernet PCB Board: adım 6, 1 resimden 1.
    • Use your Phillips #0 screwdriver to remove the three 5mm screws.
  7. Canary CAN100USBK Audio and USB PCB Board Replacement: adım 7, 2 resimden 1. Canary CAN100USBK Audio and USB PCB Board Replacement: adım 7, 2 resimden 2.
    • Place the flat end of the spudger underneath the Ethernet PCB board and slowly pry up until it's loose.
  8. Canary CAN100USBK Audio and USB PCB Board Replacement: adım 8, 1 resimden 1.
    • Carefully pull the Ethernet PCB board away from the board that sits underneath.
  9. Canary CAN100USBK Audio and USB PCB Board Replacement, Audio and USB PCB Board: adım 9, 1 resimden 1.
    • Using your fingernails, wiggle the power connector back and forth until it becomes loose.
    • Pull the power connector straight out of the socket.
    • Pull only on the power connector and not the wires themselves to prevent damage.
  10. Canary CAN100USBK Audio and USB PCB Board Replacement: adım 10, 3 resimden 1. Canary CAN100USBK Audio and USB PCB Board Replacement: adım 10, 3 resimden 2. Canary CAN100USBK Audio and USB PCB Board Replacement: adım 10, 3 resimden 3.
    • Use the spudger to pry up the retaining flap of the ZIF connector.
    • Disconnect the ribbon cable.
  11. Canary CAN100USBK Audio and USB PCB Board Replacement: adım 11, 1 resimden 1.
    • Remove the two Phillips #0 5mm screws.
  12. Canary CAN100USBK Audio and USB PCB Board Replacement: adım 12, 2 resimden 1. Canary CAN100USBK Audio and USB PCB Board Replacement: adım 12, 2 resimden 2.
    • Pull the board away from the bottom casing by lifting the end closest to the chimney up.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Kristopher Gates
399 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S1-G2, Nance Spring 2017 USF Tampa, Team S1-G2, Nance Spring 2017 üyesi
USFT-NANCE-S17S1G2
4 Üyeler
16 adet Kılavuz yazıldı
2Kılavuz Yorumları
Hello great tutorial I have a problem with the usb on mine.
Where did you buy the PCB from?
craig perrin - Yanıt
nice guide, need to buy the ep-cnc01bb-02 board which has the micro usb on it as mine is worn out... any ideas?
Billy - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 15
Her zaman: 1,088
