Ana içeriğe geç
Canary CAN100USBK Ethernet PCB Board Replacement
Neye ihtiyacın var
  1. Canary CAN100USBK Ethernet PCB Board Replacement, Bottom Casing: adım 1, 2 resimden 1. Canary CAN100USBK Ethernet PCB Board Replacement, Bottom Casing: adım 1, 2 resimden 2.
    • Grip the rubber ring with your fingers and pull up.
    • Rotate the Canary as you pull out one tab at a time.
  2. Canary CAN100USBK Ethernet PCB Board Replacement: adım 2, 1 resimden 1.
    • Use your Phillips #0 screwdriver to remove the four 6mm screws.
  3. Canary CAN100USBK Ethernet PCB Board Replacement: adım 3, 3 resimden 1. Canary CAN100USBK Ethernet PCB Board Replacement: adım 3, 3 resimden 2. Canary CAN100USBK Ethernet PCB Board Replacement: adım 3, 3 resimden 3.
    • Use the flat end of the spudger to carefully pry off the bottom casing.
    • Alternate pushing up on the left and right sides until the clips holding the case in are visible.
  4. Canary CAN100USBK Ethernet PCB Board Replacement: adım 4, 2 resimden 1. Canary CAN100USBK Ethernet PCB Board Replacement: adım 4, 2 resimden 2.
    • Do not yank the bottom off or you may damage the ribbon cable or the ZIF connector.
    • Carefully remove the bottom casing by gripping it on both sides and pulling straight up.
  5. Canary CAN100USBK Ethernet PCB Board Replacement: adım 5, 2 resimden 1. Canary CAN100USBK Ethernet PCB Board Replacement: adım 5, 2 resimden 2.
    • Use the pointed end of the spudger to flip up the small retaining flap on the ZIF (zero insertion force) connector.
    • Pull the ribbon cable out towards the device.
  6. Canary CAN100USBK Ethernet PCB Board Replacement, Ethernet PCB Board: adım 6, 1 resimden 1.
    • Use your Phillips #0 screwdriver to remove the three 5mm screws.
  7. Canary CAN100USBK Ethernet PCB Board Replacement: adım 7, 2 resimden 1. Canary CAN100USBK Ethernet PCB Board Replacement: adım 7, 2 resimden 2.
    • Place the flat end of the spudger underneath the Ethernet PCB board and slowly pry up until it's loose.
  8. Canary CAN100USBK Ethernet PCB Board Replacement: adım 8, 1 resimden 1.
    • Carefully pull the Ethernet PCB board away from the board that sits underneath.
Sonuç
Tommy Nguyen
597 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S1-G2, Nance Spring 2017 USF Tampa, Team S1-G2, Nance Spring 2017 üyesi
USFT-NANCE-S17S1G2
4 Üyeler
16 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 8
Her zaman: 1,079
