Giriş
To replace the scanner bar, the glass must first be removed, and then the scanner bar can be easily removed and replaced.
Parçalar
Hiçbir parçaya gerek yok.
  1. Slide the plastic opening tool under the plastic to unpeel it from the glass. Gently pry the plastic framing from the glass. Repeat on the other side.
    • Slide the plastic opening tool under the plastic to unpeel it from the glass.
    • Gently pry the plastic framing from the glass.
    • Repeat on the other side.
  2. Remove the front plastic frame. Remove the front plastic frame.
    • Remove the front plastic frame.
  3. Pro Tech Toolkit içeren veya $100,00tüm siparişlerde ücretsiz kargo!
    Mağazamıza Göz Atın
  4. Wedge the plastic opening tool under the glass and pull up. Slide the glass forward. Remove the glass.
    • Wedge the plastic opening tool under the glass and pull up.
    • Slide the glass forward.
    • Remove the glass.
  5. Remove the scanner bar.
    • Remove the scanner bar.
    • Replace the scanner bar back onto metal center bar.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Nick
134 İtibar
1 Kılavuz yazıldı
Takım
0 Yorum
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 8
Son 30 Gün: 21
Her zaman: 1,163
