Giriş
This guide will show you how to remove the plastic frame from the case and how to remove the scanner glass to be replaced. A little force will be necessary but with care, this guide will be fairly easy.
Parçalar
Hiçbir parçaya gerek yok.
  1. Slide the plastic opening tool under the plastic to unpeel it from the glass. Gently pry the plastic framing from the glass. Repeat on the other side.
    • Slide the plastic opening tool under the plastic to unpeel it from the glass.
    • Gently pry the plastic framing from the glass.
    • Repeat on the other side.
  2. Pro Tech Toolkit içeren veya $100,00tüm siparişlerde ücretsiz kargo!
    Mağazamıza Göz Atın
  3. Remove the front plastic frame. Remove the front plastic frame.
    • Remove the front plastic frame.
  4. Wedge the plastic opening tool under the glass and pull up. Slide the glass forward. Remove the glass.
    • Wedge the plastic opening tool under the glass and pull up.
    • Slide the glass forward.
    • Remove the glass.
Sonuç
2 başka kişi bu kılavuzu tamamladı.
Shannon
340 İtibar
2 adet Kılavuz yazıldı
Takım
Clemson, Team 1-89, Diaz Fall 2013 Clemson, Team 1-89, Diaz Fall 2013 üyesi
CLEM-DIAZ-F13S1G89
1 Üye
0 Yorum
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 Gün: 5
Son 30 Gün: 18
Her zaman: 891
