Giriş
This guide will show you how to remove the plastic frame from the case and how to remove the scanner glass to be replaced. A little force will be necessary but with care, this guide will be fairly easy.
Neye ihtiyacın var
Slide plastic opening tool under the plastic.
Gently pry the plastic framing off the glass.
Repeat on the other side.
3 farklı kişi bu kılavuzu tamamladı.
3 Yorum
Can we replace any ordinary glass ? R there are any specifications for glass quality/type ?
