Ana içeriğe geç
CanoScan LiDE 35 Square Port Removal
Neye ihtiyacın var
  1. CanoScan LiDE 35 Square Port Removal, Scanner Glass: adım 1, 3 resimden 1. CanoScan LiDE 35 Square Port Removal, Scanner Glass: adım 1, 3 resimden 2. CanoScan LiDE 35 Square Port Removal, Scanner Glass: adım 1, 3 resimden 3.
    • Slide plastic opening tool under the plastic.
    • Gently pry the plastic framing off the glass.
    • Repeat on the other side.
  2. CanoScan LiDE 35 Square Port Removal: adım 2, 2 resimden 1. CanoScan LiDE 35 Square Port Removal: adım 2, 2 resimden 2.
    • Remove the front plastic frame.
  3. CanoScan LiDE 35 Square Port Removal: adım 3, 3 resimden 1. CanoScan LiDE 35 Square Port Removal: adım 3, 3 resimden 2. CanoScan LiDE 35 Square Port Removal: adım 3, 3 resimden 3.
    • Wedge the plastic opening tool under the glass.
    • Pull up against glass.
    • Slide the glass forward.
    • Remove the glass.
  4. CanoScan LiDE 35 Square Port Removal, Square Port: adım 4, 3 resimden 1. CanoScan LiDE 35 Square Port Removal, Square Port: adım 4, 3 resimden 2. CanoScan LiDE 35 Square Port Removal, Square Port: adım 4, 3 resimden 3.
    • Locate three screws on the grey shell.
    • Unscrew the three screws.
    • Separate the grey shell from case.
  5. CanoScan LiDE 35 Square Port Removal: adım 5, 3 resimden 1. CanoScan LiDE 35 Square Port Removal: adım 5, 3 resimden 2. CanoScan LiDE 35 Square Port Removal: adım 5, 3 resimden 3.
    • Separate the grey shell from square port.
  6. CanoScan LiDE 35 Square Port Removal: adım 6, 3 resimden 1. CanoScan LiDE 35 Square Port Removal: adım 6, 3 resimden 2. CanoScan LiDE 35 Square Port Removal: adım 6, 3 resimden 3.
    • Locate the ribbon cable on casing.
    • Remove the ribbon cable on casing.
  7. CanoScan LiDE 35 Square Port Removal: adım 7, 1 resimden 1.
    • Once the ribbon cable is removed, locate the square port.
    • Remove the square port.
Sonuç
Shannon
364 İtibar
2 adet Kılavuz yazıldı
Ekip
Clemson, Team 1-89, Diaz Fall 2013 Clemson, Team 1-89, Diaz Fall 2013 üyesi
CLEM-DIAZ-F13S1G89
1 Üye
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 12
Her zaman: 883
