Giriş
This repair is useful to know how to execute if your projector has overheating issues. Often, a simple fix is just to replace a malfunctioning fan, which is a relatively cheap part. This is much more cost-effective than replacing the entire projector.
Neye ihtiyacın var
Remove the 4 exterior 9mm Phillips #0 screws. They are located on the sides of the projector.
Remove the two 7mm Phillips #0 screws that attach the fan to the motherboard of the projector.
Bir başkası bu kılavuzu tamamladı.
