Ana içeriğe geç
Canon 7210 Fan Replacement
Neye ihtiyacın var
  1. Canon 7210 Fan Replacement, Exterior Shell: adım 1, 2 resimden 1. Canon 7210 Fan Replacement, Exterior Shell: adım 1, 2 resimden 2.
    • Remove the 4 exterior 9mm Phillips #0 screws. They are located on the sides of the projector.
  2. Canon 7210 Fan Replacement: adım 2, 3 resimden 1. Canon 7210 Fan Replacement: adım 2, 3 resimden 2. Canon 7210 Fan Replacement: adım 2, 3 resimden 3.
    • Gently lift up on the shell with both hands, from the back to the front.
    • The shell will still be attached by a small cord in the front, so be careful not to tear it loose.
  3. Canon 7210 Fan Replacement, Fan: adım 3, 1 resimden 1.
    • Remove the two 7mm Phillips #0 screws that attach the fan to the motherboard of the projector.
  4. Canon 7210 Fan Replacement: adım 4, 1 resimden 1.
    • Remove the fan by pulling up gently from the top.
    • Be careful to not pull too hard or quickly, since the fan is still attached to the projector with some other wires.
  5. Canon 7210 Fan Replacement: adım 5, 1 resimden 1.
    • Remove the 7mm Phillips #0 screw that fastens the black ground wire connected to the fan and the projector.
  6. Canon 7210 Fan Replacement: adım 6, 1 resimden 1.
    • Peel the sticker up on the back of the fan to expose the port where the red, white, and black wires are attached.
    • The wires will need to be cut with small wire cutters in order to completely remove the fan.
Sonuç
Bir başkası bu kılavuzu tamamladı.
William Christian
331 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 9-3, Lacy Fall 2016 USF Tampa, Team 9-3, Lacy Fall 2016 üyesi
USFT-LACY-F16S9G3
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 313
