Ana içeriğe geç
Canon AE-1 SLR Lens Mount Replacement
Neye ihtiyacın var
  1. Canon AE-1 SLR Lens Mount Replacement, SLR Lens Mount: adım 1, 2 resimden 1. Canon AE-1 SLR Lens Mount Replacement, SLR Lens Mount: adım 1, 2 resimden 2.
    • Remove the first set of two screws from the lens outer casing using a Phillips #00 screwdriver.
    • The first set of screws is located on the front and bottom of the lens casing.
  2. Canon AE-1 SLR Lens Mount Replacement: adım 2, 2 resimden 1. Canon AE-1 SLR Lens Mount Replacement: adım 2, 2 resimden 2.
    • Remove the remaining two screws from the right and left sides of the lens outer casing using a Phillips #00 screwdriver.
  3. Canon AE-1 SLR Lens Mount Replacement: adım 3, 1 resimden 1.
    • Remove the lens casing by pulling it away from the body of the camera.
  4. Canon AE-1 SLR Lens Mount Replacement: adım 4, 1 resimden 1.
    • Remove the four #00 screws from the SLR lens mount using a Phillips #00 screwdriver.
  5. Canon AE-1 SLR Lens Mount Replacement: adım 5, 3 resimden 1. Canon AE-1 SLR Lens Mount Replacement: adım 5, 3 resimden 2. Canon AE-1 SLR Lens Mount Replacement: adım 5, 3 resimden 3.
    • Pull the SLR lens mount away from the body of the camera.
    • Be aware that a pin will fall out when the SLR lens mount is removed.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Joe Blumberg
213 İtibar
1 Kılavuz yazıldı
Ekip
UW Stout, Team 5-1, Zhou Fall 2011 UW Stout, Team 5-1, Zhou Fall 2011 üyesi
UWSTOUT-ZHOU-F11S5G1
3 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 13
Son 30 gün: 63
Her zaman: 12,183
