Ana içeriğe geç
Canon EF 16-35mm f/2.8L USM Lens Mount Replacement
Neye ihtiyacın var
  1. Canon EF 16-35mm f/2.8L USM Lens Mount Replacement, Lens Mount: adım 1, 2 resimden 1. Canon EF 16-35mm f/2.8L USM Lens Mount Replacement, Lens Mount: adım 1, 2 resimden 2.
    • If possible, try to work in an environment with minimal dust. The goal is to try to avoid dust from getting inside of the lens as much as possible.
    • Remove the two 3mm JIS #000 screws on the side of the lens mount.
    • Remove the four 8mm JIS #000 screws holding in the metal lens mount.
    • Do not pull up on the lens mount assembly. The contact assembly is still attached and you'd risk damaging the ribbon cable.
  2. Canon EF 16-35mm f/2.8L USM Lens Mount Replacement: adım 2, 2 resimden 1. Canon EF 16-35mm f/2.8L USM Lens Mount Replacement: adım 2, 2 resimden 2.
    • Gently lift up the side opposite of the contact assembly.
    • Slide your finger (or plastic spudger tool) under the lens mount and pop off the back plastic cover off of the lens.
    • Pull the lens mount assembly up and away from the lens.
Sonuç
Ekli Belgeler
Zephosk
4.744 İtibar
29 adet Kılavuz yazıldı
Ekip
LGBTQ Technicians LGBTQ Technicians üyesi
Community
33 Üyeler
68 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 50
Her zaman: 104
