Ana içeriğe geç
Canon EF 16-35mm f/2.8L USM Main PCB Board Replacement
Neye ihtiyacın var
  1. Canon EF 16-35mm f/2.8L USM Main PCB Board Replacement, Lens Mount: adım 1, 2 resimden 1. Canon EF 16-35mm f/2.8L USM Main PCB Board Replacement, Lens Mount: adım 1, 2 resimden 2.
    • If possible, try to work in an environment with minimal dust. The goal is to try to avoid dust from getting inside of the lens as much as possible.
    • Remove the two 3mm JIS #000 screws on the side of the lens mount.
    • Remove the four 8mm JIS #000 screws holding in the metal lens mount.
    • Do not pull up on the lens mount assembly. The contact assembly is still attached and you'd risk damaging the ribbon cable.
  2. Canon EF 16-35mm f/2.8L USM Main PCB Board Replacement: adım 2, 2 resimden 1. Canon EF 16-35mm f/2.8L USM Main PCB Board Replacement: adım 2, 2 resimden 2.
    • Gently lift up the side opposite of the contact assembly.
    • Slide your finger (or plastic spudger tool) under the lens mount and pop off the back plastic cover off of the lens.
    • Pull the lens mount assembly up and away from the lens.
  3. Canon EF 16-35mm f/2.8L USM Main PCB Board Replacement, Main PCB Board: adım 3, 3 resimden 1. Canon EF 16-35mm f/2.8L USM Main PCB Board Replacement, Main PCB Board: adım 3, 3 resimden 2. Canon EF 16-35mm f/2.8L USM Main PCB Board Replacement, Main PCB Board: adım 3, 3 resimden 3.
    • This step involves handling sensitive electronics. Avoid static discharge.
    • Use a pair of blunt tweezers to remove the two small ribbon cables from the main PCB board.
    • iFixit connector guide
    • Use extreme care while handling ribbon cables and connectors as they can be easy to damage.
    • Disconnect the remaining three ribbon cables.
    • Use a pair of tweezers to gently pull back the locking tabs on the ribbon cable connectors.
    • Gently remove the ribbon cables.
    • Remove the two 2.5mm JIS #000 screws from the main PCB board.
Sonuç
To reassemble your device, follow these instructions in reverse order. Use care when reconnecting the ribbon cable and ensure that they are properly seated in their connectors.
Ekli Belgeler
Zephosk
4.744 İtibar
29 adet Kılavuz yazıldı
Ekip
LGBTQ Technicians LGBTQ Technicians üyesi
Community
33 Üyeler
68 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 11
Son 30 gün: 49
Her zaman: 112
