Ana içeriğe geç
Canon ELPH Z3 Camera Battery Replacement
  1. Canon ELPH Z3 Camera Battery  Replacement, Battery: adım 1, 3 resimden 1. Canon ELPH Z3 Camera Battery  Replacement, Battery: adım 1, 3 resimden 2. Canon ELPH Z3 Camera Battery  Replacement, Battery: adım 1, 3 resimden 3.
    • Place the camera face down on a flat surface ( lens facing down).
    • Press firmly on the battery latch that is marked.
    • Slide the battery latch to the right to expose battery.
    • Detach the battery latch completely from the camera.
  2. Canon ELPH Z3 Camera Battery  Replacement: adım 2, 2 resimden 1. Canon ELPH Z3 Camera Battery  Replacement: adım 2, 2 resimden 2.
    • If the battery is leaking acid. Please proceed with extreme caution. You may sustain injury!
    • Remove the battery with a piece of double sided tape if it is leaking.
    • Use a Q-tip with a small amount of rubbing alcohol to clean battery connections.
    • Remove the existing battery using your fingers.
Sonuç
Nathan Barros
1 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-7, Catania Fall 2016 UMass Dartmouth, Team 1-7, Catania Fall 2016 üyesi
UMASSD-CATANIA-F16S1G7
3 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 13
Her zaman: 1,037
