Ana içeriğe geç
Canon ELPH Z3 Camera Film Chamber Replacement
Neye ihtiyacın var
  1. Canon ELPH Z3 Camera Film Chamber Replacement, Shutter Button: adım 1, 3 resimden 1. Canon ELPH Z3 Camera Film Chamber Replacement, Shutter Button: adım 1, 3 resimden 2. Canon ELPH Z3 Camera Film Chamber Replacement, Shutter Button: adım 1, 3 resimden 3.
    • Unscrew the 7 4.1mm screws around the camera using a PH000 screwdriver.
  2. Canon ELPH Z3 Camera Film Chamber Replacement: adım 2, 3 resimden 1. Canon ELPH Z3 Camera Film Chamber Replacement: adım 2, 3 resimden 2. Canon ELPH Z3 Camera Film Chamber Replacement: adım 2, 3 resimden 3.
    • Split the front and back coverings of the camera.
    • Remove the back covering completely.
    • This allows for easier access to the shutter button carrier.
  3. Canon ELPH Z3 Camera Film Chamber Replacement: adım 3, 2 resimden 1. Canon ELPH Z3 Camera Film Chamber Replacement: adım 3, 2 resimden 2.
    • Slide the shutter button carrier off of the camera.
    • Notice shutter button is on the right hand side of the carrier.
  4. Canon ELPH Z3 Camera Film Chamber Replacement: adım 4, 3 resimden 1. Canon ELPH Z3 Camera Film Chamber Replacement: adım 4, 3 resimden 2. Canon ELPH Z3 Camera Film Chamber Replacement: adım 4, 3 resimden 3.
    • Press upward on the shutter button from the underside of the carrier by using your thumb.
    • Separate the shutter button from the carrier.
  5. Canon ELPH Z3 Camera Film Chamber Replacement, Film: adım 5, 2 resimden 1. Canon ELPH Z3 Camera Film Chamber Replacement, Film: adım 5, 2 resimden 2.
    • Separate the front and back coverings of the camera completely.
    • Remove both coverings from the body of the camera.
    • Flip the camera upside down and focus on the bottom right portion.
  6. Canon ELPH Z3 Camera Film Chamber Replacement: adım 6, 3 resimden 1. Canon ELPH Z3 Camera Film Chamber Replacement: adım 6, 3 resimden 2. Canon ELPH Z3 Camera Film Chamber Replacement: adım 6, 3 resimden 3.
    • Unscrew the 4.1mm screw using a PH000 screwdriver.
    • Swivel the now loose metal portion to the right.
    • This action will open the film chamber and thus exposing the film.
  7. Canon ELPH Z3 Camera Film Chamber Replacement: adım 7, 3 resimden 1. Canon ELPH Z3 Camera Film Chamber Replacement: adım 7, 3 resimden 2. Canon ELPH Z3 Camera Film Chamber Replacement: adım 7, 3 resimden 3.
    • Press gently on the film using your finger to slightly eject the film.
    • Pull the film from the chamber.
Sonuç
Nathan Barros
1 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-7, Catania Fall 2016 UMass Dartmouth, Team 1-7, Catania Fall 2016 üyesi
UMASSD-CATANIA-F16S1G7
3 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 18
Her zaman: 878
