Ana içeriğe geç
Canon ELPH Z3 Camera Rear Screen Replacement
Neye ihtiyacın var
  1. Canon ELPH Z3 Camera Rear Screen Replacement, Shutter Button: adım 1, 3 resimden 1. Canon ELPH Z3 Camera Rear Screen Replacement, Shutter Button: adım 1, 3 resimden 2. Canon ELPH Z3 Camera Rear Screen Replacement, Shutter Button: adım 1, 3 resimden 3.
    • Unscrew the 7 4.1mm screws around the camera using a PH000 screwdriver.
  2. Canon ELPH Z3 Camera Rear Screen Replacement: adım 2, 3 resimden 1. Canon ELPH Z3 Camera Rear Screen Replacement: adım 2, 3 resimden 2. Canon ELPH Z3 Camera Rear Screen Replacement: adım 2, 3 resimden 3.
    • Split the front and back coverings of the camera.
    • Remove the back covering completely.
    • This allows for easier access to the shutter button carrier.
  3. Canon ELPH Z3 Camera Rear Screen Replacement: adım 3, 2 resimden 1. Canon ELPH Z3 Camera Rear Screen Replacement: adım 3, 2 resimden 2.
    • Slide the shutter button carrier off of the camera.
    • Notice shutter button is on the right hand side of the carrier.
  4. Canon ELPH Z3 Camera Rear Screen Replacement: adım 4, 3 resimden 1. Canon ELPH Z3 Camera Rear Screen Replacement: adım 4, 3 resimden 2. Canon ELPH Z3 Camera Rear Screen Replacement: adım 4, 3 resimden 3.
    • Press upward on the shutter button from the underside of the carrier by using your thumb.
    • Separate the shutter button from the carrier.
  5. Canon ELPH Z3 Camera Rear Screen Replacement, Rear Screen: adım 5, 2 resimden 1. Canon ELPH Z3 Camera Rear Screen Replacement, Rear Screen: adım 5, 2 resimden 2.
    • Pull apart the front and back coverings of the camera.
    • Remove the back covering completely to gain access of the rear screen.
  6. Canon ELPH Z3 Camera Rear Screen Replacement: adım 6, 3 resimden 1. Canon ELPH Z3 Camera Rear Screen Replacement: adım 6, 3 resimden 2. Canon ELPH Z3 Camera Rear Screen Replacement: adım 6, 3 resimden 3.
    • Unscrew the 6 4.1mm screws that are holding the back screen in place by using the PH000 screwdriver.
    • This step may require for you to pull back tape to gain access to some screws.
  7. Canon ELPH Z3 Camera Rear Screen Replacement: adım 7, 2 resimden 1. Canon ELPH Z3 Camera Rear Screen Replacement: adım 7, 2 resimden 2.
    • Pull the yellow tape away from the side that is attached to the back screen.
    • Remove the back screen.
Sonuç
Katy Skillings
1 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-7, Catania Fall 2016 UMass Dartmouth, Team 1-7, Catania Fall 2016 üyesi
UMASSD-CATANIA-F16S1G7
3 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 9
Her zaman: 356
