Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Neye ihtiyacın var
Pull up on both sides of the the eyepiece cap. It should come off with little pressure.
Remove the two screws hidden under the viewfinder eyepiece cap.
Peel off the rubber grip on the back by grasping one of the corners and pulling it away from the camera body.
Once removed, a hidden screw is revealed.
Remove both screws from the rear of the camera.
Flip the lock on the flex cable connector up with a spudger.
The front panel should pop off, now that the cable has been disconnected.
Disconnect all the indicated connectors by opening their latches.
Remove the flex cable that connects the logic board to the secondary control board.
Pull the small green connector out of its socket. Be careful when removing it, as it is possible to tear the tiny wires running into the connector.
Disconnect the two hidden connectors under the top connector indicated in pink.
Disconnect the third hidden connector.
Remove the three screws from the edges of the board.
Flip the board up and out so that the ground connection can be unscrewed.
Open the connector for the CF slot.
Remove the two screws holding the top of the CF slot in place.
Remove the one last screw holding the CF slot in on the bottom.
Remove the CF slot.
5 farklı kişi bu kılavuzu tamamladı.
