Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Neye ihtiyacın var
Pull up on both sides of the the eyepiece cap. It should come off with little pressure.
Remove the two screws hidden under the viewfinder eyepiece cap.
Peel off the rubber grip on the back by grasping one of the corners and pulling out.
Once removed, a hidden screw is revealed.
Remove both visible screws from the rear of the camera.
Flip the lock on the flex cable connector up with a spudger.
The front panel should pop off now that the cable has been disconnected.
4 farklı kişi bu kılavuzu tamamladı.
