Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Pull up on both sides of the the eyepiece cap. It should come off with little pressure.
Remove the two screws hidden under the viewfinder eyepiece cap.
Peel off the rubber grip on the back by grasping one of the corners and pulling it away from the camera body.
Once removed, a hidden screw is revealed.
Remove both screws from the rear of the camera.
Remove the two indicated screws from the bottom of the camera.
Flip the lock on the flex cable connector up with a spudger.
The front panel should pop off, now that the cable has been disconnected.
4 farklı kişi bu kılavuzu tamamladı.
