Ana içeriğe geç
Canon EOS 20D Secondary Control Board (C-Board 010) Replacement
Neye ihtiyacın var
  1. Canon EOS 20D Secondary Control Board (C-Board 010) Replacement, Remove the eyepiece cap: adım 1, 2 resimden 1. Canon EOS 20D Secondary Control Board (C-Board 010) Replacement, Remove the eyepiece cap: adım 1, 2 resimden 2.
    • Pull up on both sides of the the eyepiece cap. It should come off with little pressure.
  2. Canon EOS 20D Secondary Control Board (C-Board 010) Replacement, Remove screws from under the eyepiece cap: adım 2, 1 resimden 1.
    • Remove the two screws hidden under the viewfinder eyepiece cap.
  3. Canon EOS 20D Secondary Control Board (C-Board 010) Replacement, Remove hidden screw and other visible screw: adım 3, 3 resimden 1. Canon EOS 20D Secondary Control Board (C-Board 010) Replacement, Remove hidden screw and other visible screw: adım 3, 3 resimden 2. Canon EOS 20D Secondary Control Board (C-Board 010) Replacement, Remove hidden screw and other visible screw: adım 3, 3 resimden 3.
    • Peel off the rubber grip on the back by grasping one of the corners and pulling it away from the camera body.
    • Once removed, a hidden screw is revealed.
    • Remove both screws from the rear of the camera.
  4. Canon EOS 20D Secondary Control Board (C-Board 010) Replacement, Remove bottom screws: adım 4, 1 resimden 1.
    • Remove the two indicated screws from the bottom of the camera.
  5. Canon EOS 20D Secondary Control Board (C-Board 010) Replacement, Lift and remove the rear panel: adım 5, 3 resimden 1. Canon EOS 20D Secondary Control Board (C-Board 010) Replacement, Lift and remove the rear panel: adım 5, 3 resimden 2. Canon EOS 20D Secondary Control Board (C-Board 010) Replacement, Lift and remove the rear panel: adım 5, 3 resimden 3.
    • When lifting the panel, make sure not to lift it too high, since you'll run the risk of tearing the cable, or damaging the connector on the board.
    • Flip the lock on the flex cable connector up with a spudger.
    • The front panel should pop off, now that the cable has been disconnected.
    • When reassembling the device, make sure to insert the left side of the front panel first, since it has a small lip that needs to fit under the left part of the camera case.
  6. Canon EOS 20D Secondary Control Board (C-Board 010) Replacement, Disconnect all the labeled cables: adım 6, 3 resimden 1. Canon EOS 20D Secondary Control Board (C-Board 010) Replacement, Disconnect all the labeled cables: adım 6, 3 resimden 2. Canon EOS 20D Secondary Control Board (C-Board 010) Replacement, Disconnect all the labeled cables: adım 6, 3 resimden 3.
    • Disconnect all the indicated connectors by opening their latches.
    • Remove the flex cable that connects the logic board to the secondary control board.
    • Pull the small green connector out of its socket. Be careful when removing it, as it is possible to tear the tiny wires running into the connector.
    • Disconnect the two hidden connectors under the top connector indicated in pink.
    • Disconnect the third hidden connector.
  7. Canon EOS 20D Secondary Control Board (C-Board 010) Replacement, Remove the secondary control board: adım 7, 2 resimden 1. Canon EOS 20D Secondary Control Board (C-Board 010) Replacement, Remove the secondary control board: adım 7, 2 resimden 2.
    • Remove the three screws from the edges of the board.
    • Flip the board up and out so that the ground connection can be unscrewed.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Alec M
1.339 İtibar
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 24
Her zaman: 1,260
