Ana içeriğe geç
Canon EOS 30 Lens Mount Rings
Neye ihtiyacın var
    1. Canon EOS 30 Lens Mount Rings, Front Panel: adım 1, 1 resimden 1.
      • Remove the two 4.8 mm black screws above the lens on the front of the camera.
      FixBot'a Sor
      Yorum Ekle
    2. Canon EOS 30 Lens Mount Rings: adım 2, 1 resimden 1.
      • Remove the 4.3 mm black screw under the lens ring, and the 4.8 mm black screw under the camera.
      FixBot'a Sor
      Yorum Ekle
    3. Canon EOS 30 Lens Mount Rings: adım 3, 1 resimden 1.
      • Remove the 4.8 mm black screw on the left side of the camera.
      FixBot'a Sor
      Yorum Ekle
    4. Canon EOS 30 Lens Mount Rings: adım 4, 1 resimden 1.
      • Remove the front panel by lifting it away from the camera's body.
      FixBot'a Sor
      Yorum Ekle
    1. Canon EOS 30 Lens Mount Rings, Lens Mount Rings: adım 5, 1 resimden 1.
      • Remove four 7.1 mm silver screws from lens mount ring.
      FixBot'a Sor
      Yorum Ekle
    2. Canon EOS 30 Lens Mount Rings: adım 6, 1 resimden 1.
      • Remove outer mount ring.
      • The silver button may detach.
      FixBot'a Sor
      Yorum Ekle
    3. Canon EOS 30 Lens Mount Rings: adım 7, 1 resimden 1.
      • Remove thin gold ring.
      • Correct orientation is pictured.
      FixBot'a Sor
      Yorum Ekle
    4. Canon EOS 30 Lens Mount Rings: adım 8, 1 resimden 1.
      • Remove thin silver ring.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Antonia
124 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 8-8, Regan Spring 2011 Cal Poly, Team 8-8, Regan Spring 2011 üyesi
CPSU-REGAN-S11S8G8
5 Üyeler
44 adet Kılavuz yazıldı
1Rehber Yorum
Very handy. One addition though - the silver button lever is on the wrong side - it is not facing the mirror box but the plastic lens release button. Plus, you are missing the fact that there is a spring underneatch the silver leaver which keeps the mount pin coming back up.
Patryk Granatowicz - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 60
Her zaman: 6,302
