Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Remove the two 4.8 mm black screws above the lens on the front of the camera.
Remove the 4.3 mm black screw under the lens ring, and the 4.8 mm black screw under the camera.
Remove the 4.8 mm black screw on the left side of the camera.
Remove the front panel by lifting it away from the camera's body.
Remove seven 4.25 mm black screws on the bottom panel.
Remove the plastic remote control socket cap by pulling it straight out.
Slide the panel toward the bottom of the camera to remove.
Remove the single 4.8 silver screw from the control socket.
Desolder connections to replace the remote control socket.
Remove one 4.8 mm silver screw securing Remote Control Socket to camera.
Remote Control Socket is now secured by 3 wires.
Desolder connections to replace Remote Control Socket.
2 farklı kişi bu kılavuzu tamamladı.
