Ana içeriğe geç
Giriş
Removing the side panel with Remote Control Socket is safe and simple. It only requires a screwdriver.
Parçalar
Hiçbir parça belirtilmedi.
  1. Canon EOS 30 Side Panel With Remote Control Socket Replacement, Front Panel: step 1, image 1 of 1
    • Remove the two 4.8 mm black screws above the lens on the front of the camera.
  2. Canon EOS 30 Side Panel With Remote Control Socket Replacement: step 2, image 1 of 1
    • Remove the 4.3 mm black screw under the lens ring, and the 4.8 mm black screw under the camera.
  3. Canon EOS 30 Side Panel With Remote Control Socket Replacement: step 3, image 1 of 1
    • Remove the 4.8 mm black screw on the left side of the camera.
  4. Canon EOS 30 Side Panel With Remote Control Socket Replacement: step 4, image 1 of 1
    • Remove the front panel by lifting it away from the camera's body.
  5. Canon EOS 30 Side Panel With Remote Control Socket Replacement, Bottom Panel: step 5, image 1 of 1
    • Remove seven 4.25 mm black screws on the bottom panel.
  6. Canon EOS 30 Side Panel With Remote Control Socket Replacement: step 6, image 1 of 1
    • Remove the bottom panel.
  7. Canon EOS 30 Side Panel With Remote Control Socket Replacement, Side Panel With Remote Control Socket: step 7, image 1 of 1
    • Remove two 6.5 mm black screws from the panel.
  8. Canon EOS 30 Side Panel With Remote Control Socket Replacement: step 8, image 1 of 1
    • Remove the plastic remote control socket cap by pulling it straight out.
  9. Canon EOS 30 Side Panel With Remote Control Socket Replacement: step 9, image 1 of 2 Canon EOS 30 Side Panel With Remote Control Socket Replacement: step 9, image 2 of 2
    • Slide panel toward bottom of camera to remove.
Sonuç
Sterling Vinson
226 İtibar
5 adet Kılavuz yazıldı
Takım
Cal Poly, Team 8-8, Regan Spring 2011 Cal Poly, Team 8-8, Regan Spring 2011 üyesi
CPSU-REGAN-S11S8G8
5 Üyeler
22 adet Kılavuz yazıldı
3 Yorum
i have this camera and the door that holds the film in will not stay closed because the plastic piece has broken at the release point. Which piece is it that I need to replace?
luederscoupons - Yanıt
That's a bit of a bugger. The piece that's broken off is most likely the little "hook" on the "door" (the proper name of this "door" would be "back").
Since this little hook is integral with the back, you'd have to replace the entire back.
If you still have the piece that has broken off, it may be possible to glue it back in place, but you'd have to reinforce it with e.g. a small piece of aluminium sheet cut from a soft drink can or something like that. Use cyanoacrylate glue (otherwise known as "superglue") and make sure the pieces are clean and fit perfectly before applying the glue. You need only a tiny drop.
Flying Dutchman -
The EOS 30 is a film camera and therefore does not have an A/V Port, since it does neither Audio nor Video. The socket near the bottom on the grip side is for a wired remote control.
Flying Dutchman - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 1,584
