Ana içeriğe geç
Canon EOS 300 Back Lock-Release Lever Replacement
Neye ihtiyacın var
    1. Canon EOS 300 Back Lock-Release Lever Replacement, Batteries: adım 1, 3 resimden 1. Canon EOS 300 Back Lock-Release Lever Replacement, Batteries: adım 1, 3 resimden 2. Canon EOS 300 Back Lock-Release Lever Replacement, Batteries: adım 1, 3 resimden 3.
      • Open up the battery door.
      FixBot'a Sor
      Yorum Ekle
    2. Canon EOS 300 Back Lock-Release Lever Replacement: adım 2, 2 resimden 1. Canon EOS 300 Back Lock-Release Lever Replacement: adım 2, 2 resimden 2.
      • Remove the batteries from the camera by sliding them out into your palm.
      FixBot'a Sor
      Yorum Ekle
    1. Canon EOS 300 Back Lock-Release Lever Replacement, Side Panel with Lever: adım 3, 2 resimden 1. Canon EOS 300 Back Lock-Release Lever Replacement, Side Panel with Lever: adım 3, 2 resimden 2.
      • Release the side latch to open the back panel.
      FixBot'a Sor
      Yorum Ekle
    2. Canon EOS 300 Back Lock-Release Lever Replacement: adım 4, 2 resimden 1. Canon EOS 300 Back Lock-Release Lever Replacement: adım 4, 2 resimden 2.
      • Remove the two black 4.5mm screws above and below the latch.
      FixBot'a Sor
      Yorum Ekle
    3. Canon EOS 300 Back Lock-Release Lever Replacement: adım 5, 2 resimden 1. Canon EOS 300 Back Lock-Release Lever Replacement: adım 5, 2 resimden 2.
      • Using your finger, carefully pry open the side panel from the top of camera.
      • Pull panel downwards to remove.
      • Make sure to keep track of the small black piece of rubber under the latch.
      FixBot'a Sor
      Yorum Ekle
    1. Canon EOS 300 Back Lock-Release Lever Replacement, Front Panel: adım 6, 2 resimden 1. Canon EOS 300 Back Lock-Release Lever Replacement, Front Panel: adım 6, 2 resimden 2.
      • Remove the two silver 6mm Phillips #1 screws.
      FixBot'a Sor
      Yorum Ekle
    2. Canon EOS 300 Back Lock-Release Lever Replacement: adım 7, 2 resimden 1. Canon EOS 300 Back Lock-Release Lever Replacement: adım 7, 2 resimden 2.
      • Flip camera over to the bottom.
      • Remove the one 5mm Phillips #1 silver screw.
      FixBot'a Sor
      Yorum Ekle
    3. Canon EOS 300 Back Lock-Release Lever Replacement: adım 8, 2 resimden 1. Canon EOS 300 Back Lock-Release Lever Replacement: adım 8, 2 resimden 2.
      • Remove the front panel by pulling away from the side with the lever.
      FixBot'a Sor
      Yorum Ekle
    1. Canon EOS 300 Back Lock-Release Lever Replacement, Back Lock-Release Lever: adım 9, 3 resimden 1. Canon EOS 300 Back Lock-Release Lever Replacement, Back Lock-Release Lever: adım 9, 3 resimden 2. Canon EOS 300 Back Lock-Release Lever Replacement, Back Lock-Release Lever: adım 9, 3 resimden 3.
      • Pull off the lever by pushing up from the bottom and pulling away from the bottom.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Jordan Tang
608 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 6-20, Maness Winter 2014 Cal Poly, Team 6-20, Maness Winter 2014 üyesi
CPSU-MANESS-W14S6G20
4 Üyeler
32 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 10
Son 30 gün: 54
Her zaman: 2,741
