Ana içeriğe geç
Canon EOS 300 Bottom Panel Replacement
Neye ihtiyacın var
  1. Canon EOS 300 Bottom Panel Replacement, Batteries: adım 1, 3 resimden 1. Canon EOS 300 Bottom Panel Replacement, Batteries: adım 1, 3 resimden 2. Canon EOS 300 Bottom Panel Replacement, Batteries: adım 1, 3 resimden 3.
    • Open up the battery door.
  2. Canon EOS 300 Bottom Panel Replacement: adım 2, 2 resimden 1. Canon EOS 300 Bottom Panel Replacement: adım 2, 2 resimden 2.
    • Remove the batteries from the camera by sliding them out into your palm.
  3. Canon EOS 300 Bottom Panel Replacement, Side Panel with Lever: adım 3, 2 resimden 1. Canon EOS 300 Bottom Panel Replacement, Side Panel with Lever: adım 3, 2 resimden 2.
    • Release the side latch to open the back panel.
  4. Canon EOS 300 Bottom Panel Replacement: adım 4, 2 resimden 1. Canon EOS 300 Bottom Panel Replacement: adım 4, 2 resimden 2.
    • Remove the two black 4.5mm screws above and below the latch.
  5. Canon EOS 300 Bottom Panel Replacement: adım 5, 2 resimden 1. Canon EOS 300 Bottom Panel Replacement: adım 5, 2 resimden 2.
    • Using your finger, carefully pry open the side panel from the top of camera.
    • Pull panel downwards to remove.
    • Make sure to keep track of the small black piece of rubber under the latch.
  6. Canon EOS 300 Bottom Panel Replacement, Front Panel: adım 6, 2 resimden 1. Canon EOS 300 Bottom Panel Replacement, Front Panel: adım 6, 2 resimden 2.
    • Remove the two silver 6mm Phillips #1 screws.
  7. Canon EOS 300 Bottom Panel Replacement: adım 7, 2 resimden 1. Canon EOS 300 Bottom Panel Replacement: adım 7, 2 resimden 2.
    • Flip camera over to the bottom.
    • Remove the one 5mm Phillips #1 silver screw.
  8. Canon EOS 300 Bottom Panel Replacement: adım 8, 2 resimden 1. Canon EOS 300 Bottom Panel Replacement: adım 8, 2 resimden 2.
    • Remove the front panel by pulling away from the side with the lever.
  9. Canon EOS 300 Bottom Panel Replacement, Bottom Panel: adım 9, 2 resimden 1. Canon EOS 300 Bottom Panel Replacement, Bottom Panel: adım 9, 2 resimden 2.
    • Remove three black 7.3mm Phillips #1 screws located on the corners of the camera.
    • Remove five black 4.8mm Phillips #1 screws.
  10. Canon EOS 300 Bottom Panel Replacement: adım 10, 3 resimden 1. Canon EOS 300 Bottom Panel Replacement: adım 10, 3 resimden 2. Canon EOS 300 Bottom Panel Replacement: adım 10, 3 resimden 3.
    • Simply remove the bottom panel by prying it off with your finger.
    • When removing the panel, be sure the bottom of the camera is facing upright. There are loose gears that may fall out.
    • Be wary of a loose piece of foam attached to the bottom panel.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Tammy Kong
805 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 6-20, Maness Winter 2014 Cal Poly, Team 6-20, Maness Winter 2014 üyesi
CPSU-MANESS-W14S6G20
4 Üyeler
32 adet Kılavuz yazıldı
1Rehber Yorum
muy buena la explicacion de como desmontar la maquina. Te has gadano los 30 puntos
Ricardo Alonso Gurrea - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 45
Her zaman: 982
