Ana içeriğe geç
Canon EOS 300 Command Dial Replacement
Neye ihtiyacın var
    1. Canon EOS 300 Command Dial Replacement, Batteries: adım 1, 3 resimden 1. Canon EOS 300 Command Dial Replacement, Batteries: adım 1, 3 resimden 2. Canon EOS 300 Command Dial Replacement, Batteries: adım 1, 3 resimden 3.
      • Open up the battery door.
      FixBot'a Sor
      Yorum Ekle
    2. Canon EOS 300 Command Dial Replacement: adım 2, 2 resimden 1. Canon EOS 300 Command Dial Replacement: adım 2, 2 resimden 2.
      • Remove the batteries from the camera by sliding them out into your palm.
      FixBot'a Sor
      Yorum Ekle
    1. Canon EOS 300 Command Dial Replacement, Side Panel with Lever: adım 3, 2 resimden 1. Canon EOS 300 Command Dial Replacement, Side Panel with Lever: adım 3, 2 resimden 2.
      • Release the side latch to open the back panel.
      FixBot'a Sor
      Yorum Ekle
    2. Canon EOS 300 Command Dial Replacement: adım 4, 2 resimden 1. Canon EOS 300 Command Dial Replacement: adım 4, 2 resimden 2.
      • Remove the two black 4.5mm screws above and below the latch.
      FixBot'a Sor
      Yorum Ekle
    3. Canon EOS 300 Command Dial Replacement: adım 5, 2 resimden 1. Canon EOS 300 Command Dial Replacement: adım 5, 2 resimden 2.
      • Using your finger, carefully pry open the side panel from the top of camera.
      • Pull panel downwards to remove.
      • Make sure to keep track of the small black piece of rubber under the latch.
      FixBot'a Sor
      Yorum Ekle
    1. Canon EOS 300 Command Dial Replacement, Front Panel: adım 6, 2 resimden 1. Canon EOS 300 Command Dial Replacement, Front Panel: adım 6, 2 resimden 2.
      • Remove the two silver 6mm Phillips #1 screws.
      FixBot'a Sor
      Yorum Ekle
    2. Canon EOS 300 Command Dial Replacement: adım 7, 2 resimden 1. Canon EOS 300 Command Dial Replacement: adım 7, 2 resimden 2.
      • Flip camera over to the bottom.
      • Remove the one 5mm Phillips #1 silver screw.
      FixBot'a Sor
      Yorum Ekle
    3. Canon EOS 300 Command Dial Replacement: adım 8, 2 resimden 1. Canon EOS 300 Command Dial Replacement: adım 8, 2 resimden 2.
      • Remove the front panel by pulling away from the side with the lever.
      FixBot'a Sor
      Yorum Ekle
    1. Canon EOS 300 Command Dial Replacement, Bottom Panel: adım 9, 2 resimden 1. Canon EOS 300 Command Dial Replacement, Bottom Panel: adım 9, 2 resimden 2.
      • Remove three black 7.3mm Phillips #1 screws located on the corners of the camera.
      • Remove five black 4.8mm Phillips #1 screws.
      FixBot'a Sor
      Yorum Ekle
    2. Canon EOS 300 Command Dial Replacement: adım 10, 3 resimden 1. Canon EOS 300 Command Dial Replacement: adım 10, 3 resimden 2. Canon EOS 300 Command Dial Replacement: adım 10, 3 resimden 3.
      • Simply remove the bottom panel by prying it off with your finger.
      • When removing the panel, be sure the bottom of the camera is facing upright. There are loose gears that may fall out.
      • Be wary of a loose piece of foam attached to the bottom panel.
      FixBot'a Sor
      Yorum Ekle
    1. Canon EOS 300 Command Dial Replacement, Side Panel with Grip: adım 11, 3 resimden 1. Canon EOS 300 Command Dial Replacement, Side Panel with Grip: adım 11, 3 resimden 2. Canon EOS 300 Command Dial Replacement, Side Panel with Grip: adım 11, 3 resimden 3.
      • Remove the remote control socket cover.
      FixBot'a Sor
      Yorum Ekle
    2. Canon EOS 300 Command Dial Replacement: adım 12, 2 resimden 1. Canon EOS 300 Command Dial Replacement: adım 12, 2 resimden 2.
      • Remove two black 4.5mm Phillips #1 screws.
      FixBot'a Sor
      Yorum Ekle
    3. Canon EOS 300 Command Dial Replacement: adım 13, 2 resimden 1. Canon EOS 300 Command Dial Replacement: adım 13, 2 resimden 2.
      • Remove two black 4.8mm Phillips #1 screws on the front of the camera.
      FixBot'a Sor
      Yorum Ekle
    4. Canon EOS 300 Command Dial Replacement: adım 14, 2 resimden 1. Canon EOS 300 Command Dial Replacement: adım 14, 2 resimden 2.
      • Pry open the side grip using a spudger.
      FixBot'a Sor
      Yorum Ekle
    1. Canon EOS 300 Command Dial Replacement, Eyecup: adım 15, 2 resimden 1. Canon EOS 300 Command Dial Replacement, Eyecup: adım 15, 2 resimden 2.
      • With your hands, remove the rubber grip from the eye piece.
      FixBot'a Sor
      Yorum Ekle
    2. Canon EOS 300 Command Dial Replacement: adım 16, 1 resimden 1.
      • Remove the eyecup from the eyepiece by pushing the eyecup up.
      FixBot'a Sor
      Yorum Ekle
    1. Canon EOS 300 Command Dial Replacement, Top Panel: adım 17, 2 resimden 1. Canon EOS 300 Command Dial Replacement, Top Panel: adım 17, 2 resimden 2.
      • Remove two silver 5.0mm Phillips #1 screws.
      FixBot'a Sor
      Yorum Ekle
    2. Canon EOS 300 Command Dial Replacement: adım 18, 1 resimden 1.
      • Remove the silver 5.5mm Phillips #1 screw.
      FixBot'a Sor
      Yorum Ekle
    3. Canon EOS 300 Command Dial Replacement: adım 19, 2 resimden 1. Canon EOS 300 Command Dial Replacement: adım 19, 2 resimden 2.
      • Pry the top silver part of the camera off.
      • Buttons may slip out of the camera's top as the top is pulled off the camera (shown in picture two).
      FixBot'a Sor
      Yorum Ekle
    1. Canon EOS 300 Command Dial Replacement, Command Dial: adım 20, 3 resimden 1. Canon EOS 300 Command Dial Replacement, Command Dial: adım 20, 3 resimden 2. Canon EOS 300 Command Dial Replacement, Command Dial: adım 20, 3 resimden 3.
      • On the top panel, remove the silver 3.8mm Phillips #1 screw right below the command dial.
      • A small metal piece will come off with the screw.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Tammy Kong
805 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 6-20, Maness Winter 2014 Cal Poly, Team 6-20, Maness Winter 2014 üyesi
CPSU-MANESS-W14S6G20
4 Üyeler
132 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 15
Son 30 gün: 50
Her zaman: 2,464
