Ana içeriğe geç
Canon EOS 300 Eyepiece Replacement
Neye ihtiyacın var
  1. Canon EOS 300 Eyepiece Replacement, Batteries: adım 1, 3 resimden 1. Canon EOS 300 Eyepiece Replacement, Batteries: adım 1, 3 resimden 2. Canon EOS 300 Eyepiece Replacement, Batteries: adım 1, 3 resimden 3.
    • Open up the battery door.
  2. Canon EOS 300 Eyepiece Replacement: adım 2, 2 resimden 1. Canon EOS 300 Eyepiece Replacement: adım 2, 2 resimden 2.
    • Remove the batteries from the camera by sliding them out into your palm.
  3. Canon EOS 300 Eyepiece Replacement, Side Panel with Lever: adım 3, 2 resimden 1. Canon EOS 300 Eyepiece Replacement, Side Panel with Lever: adım 3, 2 resimden 2.
    • Release the side latch to open the back panel.
  4. Canon EOS 300 Eyepiece Replacement: adım 4, 2 resimden 1. Canon EOS 300 Eyepiece Replacement: adım 4, 2 resimden 2.
    • Remove the two black 4.5mm screws above and below the latch.
  5. Canon EOS 300 Eyepiece Replacement: adım 5, 2 resimden 1. Canon EOS 300 Eyepiece Replacement: adım 5, 2 resimden 2.
    • Using your finger, carefully pry open the side panel from the top of camera.
    • Pull panel downwards to remove.
    • Make sure to keep track of the small black piece of rubber under the latch.
  6. Canon EOS 300 Eyepiece Replacement, Front Panel: adım 6, 2 resimden 1. Canon EOS 300 Eyepiece Replacement, Front Panel: adım 6, 2 resimden 2.
    • Remove the two silver 6mm Phillips #1 screws.
  7. Canon EOS 300 Eyepiece Replacement: adım 7, 2 resimden 1. Canon EOS 300 Eyepiece Replacement: adım 7, 2 resimden 2.
    • Flip camera over to the bottom.
    • Remove the one 5mm Phillips #1 silver screw.
  8. Canon EOS 300 Eyepiece Replacement: adım 8, 2 resimden 1. Canon EOS 300 Eyepiece Replacement: adım 8, 2 resimden 2.
    • Remove the front panel by pulling away from the side with the lever.
  9. Canon EOS 300 Eyepiece Replacement, Bottom Panel: adım 9, 2 resimden 1. Canon EOS 300 Eyepiece Replacement, Bottom Panel: adım 9, 2 resimden 2.
    • Remove three black 7.3mm Phillips #1 screws located on the corners of the camera.
    • Remove five black 4.8mm Phillips #1 screws.
  10. Canon EOS 300 Eyepiece Replacement: adım 10, 3 resimden 1. Canon EOS 300 Eyepiece Replacement: adım 10, 3 resimden 2. Canon EOS 300 Eyepiece Replacement: adım 10, 3 resimden 3.
    • Simply remove the bottom panel by prying it off with your finger.
    • When removing the panel, be sure the bottom of the camera is facing upright. There are loose gears that may fall out.
    • Be wary of a loose piece of foam attached to the bottom panel.
  11. Canon EOS 300 Eyepiece Replacement, Side Panel with Grip: adım 11, 3 resimden 1. Canon EOS 300 Eyepiece Replacement, Side Panel with Grip: adım 11, 3 resimden 2. Canon EOS 300 Eyepiece Replacement, Side Panel with Grip: adım 11, 3 resimden 3.
    • Remove the remote control socket cover.
  12. Canon EOS 300 Eyepiece Replacement: adım 12, 2 resimden 1. Canon EOS 300 Eyepiece Replacement: adım 12, 2 resimden 2.
    • Remove two black 4.5mm Phillips #1 screws.
  13. Canon EOS 300 Eyepiece Replacement: adım 13, 2 resimden 1. Canon EOS 300 Eyepiece Replacement: adım 13, 2 resimden 2.
    • Remove two black 4.8mm Phillips #1 screws on the front of the camera.
  14. Canon EOS 300 Eyepiece Replacement: adım 14, 2 resimden 1. Canon EOS 300 Eyepiece Replacement: adım 14, 2 resimden 2.
    • Pry open the side grip using a spudger.
  15. Canon EOS 300 Eyepiece Replacement, Eyecup: adım 15, 2 resimden 1. Canon EOS 300 Eyepiece Replacement, Eyecup: adım 15, 2 resimden 2.
    • With your hands, remove the rubber grip from the eye piece.
  16. Canon EOS 300 Eyepiece Replacement: adım 16, 1 resimden 1.
    • Remove the eyecup from the eyepiece by pushing the eyecup up.
  17. Canon EOS 300 Eyepiece Replacement, Top Panel: adım 17, 2 resimden 1. Canon EOS 300 Eyepiece Replacement, Top Panel: adım 17, 2 resimden 2.
    • Remove two silver 5.0mm Phillips #1 screws.
  18. Canon EOS 300 Eyepiece Replacement: adım 18, 1 resimden 1.
    • Remove the silver 5.5mm Phillips #1 screw.
  19. Canon EOS 300 Eyepiece Replacement: adım 19, 2 resimden 1. Canon EOS 300 Eyepiece Replacement: adım 19, 2 resimden 2.
    • Pry the top silver part of the camera off.
    • Buttons may slip out of the camera's top as the top is pulled off the camera (shown in picture two).
  20. Canon EOS 300 Eyepiece Replacement, Eyepiece: adım 20, 2 resimden 1. Canon EOS 300 Eyepiece Replacement, Eyepiece: adım 20, 2 resimden 2.
    • Remove the two black 9.5mm screws.
  21. Canon EOS 300 Eyepiece Replacement: adım 21, 3 resimden 1. Canon EOS 300 Eyepiece Replacement: adım 21, 3 resimden 2. Canon EOS 300 Eyepiece Replacement: adım 21, 3 resimden 3.
    • Remove two black 8.8mm Phillips #1 screws with a screw driver.
    • Remove the right screw first (the one without the tape).
Sonuç
Tammy Kong
771 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 6-20, Maness Winter 2014 Cal Poly, Team 6-20, Maness Winter 2014 üyesi
CPSU-MANESS-W14S6G20
4 Üyeler
32 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 32
Her zaman: 830
