Ana içeriğe geç
Canon EOS 300 Side Panel with Lever Replacement
Neye ihtiyacın var
  1. Canon EOS 300 Side Panel with Lever Replacement, Batteries: adım 1, 3 resimden 1. Canon EOS 300 Side Panel with Lever Replacement, Batteries: adım 1, 3 resimden 2. Canon EOS 300 Side Panel with Lever Replacement, Batteries: adım 1, 3 resimden 3.
    • Open up the battery door.
    FixBot'a Sor
    Yorum Ekle
  2. Canon EOS 300 Side Panel with Lever Replacement: adım 2, 2 resimden 1. Canon EOS 300 Side Panel with Lever Replacement: adım 2, 2 resimden 2.
    • Remove the batteries from the camera by sliding them out into your palm.
    FixBot'a Sor
    Yorum Ekle
  3. Canon EOS 300 Side Panel with Lever Replacement, Side Panel with Lever: adım 3, 2 resimden 1. Canon EOS 300 Side Panel with Lever Replacement, Side Panel with Lever: adım 3, 2 resimden 2.
    • Release the side latch to open the back panel.
    FixBot'a Sor
    Yorum Ekle
  4. Canon EOS 300 Side Panel with Lever Replacement: adım 4, 2 resimden 1. Canon EOS 300 Side Panel with Lever Replacement: adım 4, 2 resimden 2.
    • Remove the two black 4.5mm screws above and below the latch.
    FixBot'a Sor
    Yorum Ekle
  5. Canon EOS 300 Side Panel with Lever Replacement: adım 5, 2 resimden 1. Canon EOS 300 Side Panel with Lever Replacement: adım 5, 2 resimden 2.
    • Using your finger, carefully pry open the side panel from the top of camera.
    • Pull panel downwards to remove.
    • Make sure to keep track of the small black piece of rubber under the latch.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Jordan Tang
608 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 6-20, Maness Winter 2014 Cal Poly, Team 6-20, Maness Winter 2014 üyesi
CPSU-MANESS-W14S6G20
4 Üyeler
32 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 13
Son 30 gün: 44
Her zaman: 962
