Ana içeriğe geç
Canon EOS 40D Flash Hot Shoe Replacement
Neye ihtiyacın var
    1. Canon EOS 40D Flash Hot Shoe Replacement, Battery: adım 1, 1 resimden 1.
      • Locate the battery compartment cover on the bottom of the camera below the shutter button.
      FixBot'a Sor
      Yorum Ekle
    2. Canon EOS 40D Flash Hot Shoe Replacement: adım 2, 1 resimden 1.
      • Find the marked arrow on the battery compartment cover labeled "BATT. OPEN". Slide the lever following the arrow's direction and lift at the same time to release the latch.
      FixBot'a Sor
      Yorum Ekle
    3. Canon EOS 40D Flash Hot Shoe Replacement: adım 3, 1 resimden 1.
      • Release the lever and allow the battery compartment cover to completely open.
      • Remove the battery.
      FixBot'a Sor
      Yorum Ekle
    1. Canon EOS 40D Flash Hot Shoe Replacement, Flash Hot Shoe: adım 4, 3 resimden 1. Canon EOS 40D Flash Hot Shoe Replacement, Flash Hot Shoe: adım 4, 3 resimden 2. Canon EOS 40D Flash Hot Shoe Replacement, Flash Hot Shoe: adım 4, 3 resimden 3.
      • Use a metal spudger or opening tool to gently lift the hotshoe plate and slide it off.
      FixBot'a Sor
      Yorum Ekle
    2. Canon EOS 40D Flash Hot Shoe Replacement: adım 5, 3 resimden 1. Canon EOS 40D Flash Hot Shoe Replacement: adım 5, 3 resimden 2. Canon EOS 40D Flash Hot Shoe Replacement: adım 5, 3 resimden 3.
      • Remove the four 4.0 mm Phillips #000 screws securing the flash shoe to the camera.
      • Remove the flash shoe.
      FixBot'a Sor
      Yorum Ekle
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Sarah de Freitas
277 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 12-3, Blackwell Fall 2015 USF Tampa, Team 12-3, Blackwell Fall 2015 üyesi
USFT-BLACKWELL-F15S12G3
4 Üyeler
36 adet Kılavuz yazıldı
1Rehber Yorum
This is the best down to earth instructions i have ever had. No messing about even tells what screws and how to open the battery cover
Albert
albert irving - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 14
Son 30 gün: 80
Her zaman: 5,713
