Giriş
Follow this guide if your LCD monitor is cracked, shattered, or does not display any images. Please purchase a 3.0 inch LCD monitor for the Canon EOS 40D before you continue to the first step.
Neye ihtiyacın var
Locate the battery compartment cover on the bottom of the camera below the shutter button.
Remove the side cover using a plastic opening tool or your hands.
Use a plastic opening tool to gently start prying the rear case up from the rest of the camera.
Use the tip of a spudger to disconnect the ZIF connector on the left side of the camera. The ribbon cable on this device was torn in the process of removing the back case, so there are no photos showing this step.
Disconnect the ribbon cable securing the rear case to the motherboard.
Separate the rear case from the camera.
3 farklı kişi bu kılavuzu tamamladı.
2Kılavuz Yorumları
On the unit are brought on eBay for parts all the screws came out fine.But on the camera I was repairing I had to remove the left hand viewfinder screw by takings its head off with a Dremel rotary tool!!!
