Ana içeriğe geç
Canon EOS 5D Mark II Clock Battery Replacement
Neye ihtiyacın var
    1. Canon EOS 5D Mark II Clock Battery Replacement, Clock Battery: adım 1, 1 resimden 1.
      • Lift the rubber flap covering the input/output jacks.
      FixBot'a Sor
      Yorum Ekle
    2. Canon EOS 5D Mark II Clock Battery Replacement: adım 2, 1 resimden 1.
      • Using a Phillips #000, remove the single 3.4 mm screw.
      FixBot'a Sor
      Yorum Ekle
    3. Canon EOS 5D Mark II Clock Battery Replacement: adım 3, 1 resimden 1.
      • This step will permanently erase all user settings.
      • The memory battery can now be easily slid out of place.
      • If you are following this guide in an effort to perform a hard reset, you should now press the shutter button multiple times in order to drain any left over power, then replace the batteries and power the device back on. You have just performed a hard reset!
      FixBot'a Sor
      Yorum Ekle
Sonuç
17 farklı kişi bu kılavuzu tamamladı.
Mike Seed
3.166 İtibar
8 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-6, Hickman Fall 2014 USF Tampa, Team 1-6, Hickman Fall 2014 üyesi
USFT-HICKMAN-F14S1G6
3 Üyeler
17 adet Kılavuz yazıldı
4Kılavuz Yorumları
This Battery for Clock only? or CMos and Personal setting to?
there has to be something to retain all these settings once the main battery pack goes dead and or is removed from the camera?
My User 1 Pictures styles wont Save? it'll save but once i turn off My Canon Eos 5D Mark II and then back on again, my Color /Contrast/Sharpness are all Dead Center/= back to Default AGAIN? :/
Any Help here?
THANK YOU,
Greg - Yanıt Paylaş
I did not write the original post, but I believe once you remove this battery ALL custom changes and time will be gone. You will have to re-create them. Besides the rechargeable battery, the only one keeping track of some settings is this one.
CL
Carlos Lijeron - Yanıt Paylaş
Will doing this reset the shutter count in the camera? Like when you go to an external program to see how many shutter actuations there have been over the lifetime of the camera, will that number be erased?
Tom Fewchuk - Yanıt Paylaş
No, because some faulty behavior i removed my clock battery from my 5D MK2, but the shutter count is still the same, it would be to easy to hack a camera to be sold on a good price. :)
Vass János Szilárd - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 22
Son 30 gün: 97
Her zaman: 29,249
