Ana içeriğe geç
Canon EOS 5D Mark II Front Panel Replacement
Neye ihtiyacın var
  1. Canon EOS 5D Mark II Front Panel Replacement, Back Panel: adım 1, 1 resimden 1.
    • Peel back the rubber cover above the in/out ports to reveal two screw heads.
    FixBot'a Sor
    Yorum Ekle
  2. Canon EOS 5D Mark II Front Panel Replacement: adım 2, 1 resimden 1.
    • Remove both 5.4 mm screws using a Phillips #0.
    FixBot'a Sor
    Yorum Ekle
  3. Canon EOS 5D Mark II Front Panel Replacement: adım 3, 1 resimden 1.
    • Lift the in/out port plastic covering from the bottom where the backup battery used to be.
    FixBot'a Sor
    Yorum Ekle
  4. Canon EOS 5D Mark II Front Panel Replacement: adım 4, 1 resimden 1.
    • Remove each 6.3 mm screw on either side of the viewfinder using a Phillips #0 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  5. Canon EOS 5D Mark II Front Panel Replacement: adım 5, 1 resimden 1.
    • Remove the three 4.8 mm screws on the bottom of the back plate using a Phillips #0.
    FixBot'a Sor
    Yorum Ekle
  6. Canon EOS 5D Mark II Front Panel Replacement: adım 6, 1 resimden 1.
    • Peel back the rubber covering next to the menu dial to access the screw.
    • Remove the single 3.4 mm screw using a Phillips #0.
    FixBot'a Sor
    Yorum Ekle
  7. Canon EOS 5D Mark II Front Panel Replacement: adım 7, 1 resimden 1.
    • The back panel can now fall off easily by turning the device upside down. Be sure to catch it so the data ribbons do not tear or tug.
    FixBot'a Sor
    Yorum Ekle
  8. Canon EOS 5D Mark II Front Panel Replacement: adım 8, 1 resimden 1.
    • Remove each data ribbon cable from the motherboard by applying pressure down towards the motherboard and gently sliding your thumb upwards on the slot where the cable meets the motherboard. This will raise a very small clip that locks the cable in place.
    • The back panel is now free from the rest of the device.
    FixBot'a Sor
    Yorum Ekle
  9. Canon EOS 5D Mark II Front Panel Replacement, Front Panel: adım 9, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Using tweezers, pull out the wire attaching the front panel to the motherboard.
    FixBot'a Sor
    Yorum Ekle
  10. Canon EOS 5D Mark II Front Panel Replacement: adım 10, 1 resimden 1.
    • Peel off the rubber cover on the front panel in order to access the screws underneath.
    FixBot'a Sor
    Yorum Ekle
  11. Canon EOS 5D Mark II Front Panel Replacement: adım 11, 1 resimden 1.
    • Remove each of the 4.9 mm three screws using a Phillips #0.
    FixBot'a Sor
    Yorum Ekle
  12. Canon EOS 5D Mark II Front Panel Replacement: adım 12, 1 resimden 1.
    • Remove the two 4.8 mm screws above where the lens would be using a Phillips #0.
    FixBot'a Sor
    Yorum Ekle
  13. Canon EOS 5D Mark II Front Panel Replacement: adım 13, 1 resimden 1.
    • Remove the single screw underneath where the lens would be using a Phillips #0.
    FixBot'a Sor
    Yorum Ekle
  14. Canon EOS 5D Mark II Front Panel Replacement: adım 14, 3 resimden 1. Canon EOS 5D Mark II Front Panel Replacement: adım 14, 3 resimden 2. Canon EOS 5D Mark II Front Panel Replacement: adım 14, 3 resimden 3.
    • Remove the four 3.0 mm screws next to the memory card reader using a Phillips #0.
    FixBot'a Sor
    Yorum Ekle
  15. Canon EOS 5D Mark II Front Panel Replacement: adım 15, 2 resimden 1. Canon EOS 5D Mark II Front Panel Replacement: adım 15, 2 resimden 2.
    • Remove the front panel by lifting upwards from the right side where the in/out ports used to be.
    FixBot'a Sor
    Yorum Ekle
Sonuç
14 farklı kişi bu kılavuzu tamamladı.
Mike Seed
3.166 İtibar
8 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-6, Hickman Fall 2014 USF Tampa, Team 1-6, Hickman Fall 2014 üyesi
USFT-HICKMAN-F14S1G6
3 Üyeler
17 adet Kılavuz yazıldı
1Rehber Yorum
Good write-up. I just replaced my casing using these instructions.
sebastien - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 19
Son 30 gün: 107
Her zaman: 12,620
