Giriş
This guide will show users how to remove the front panel. It is necessary to remove the front panel in order to remove the top panel and access many internal components.
Neye ihtiyacın var
Peel back the rubber cover above the in/out ports to reveal two screw heads.
Remove each data ribbon cable from the motherboard by applying pressure down towards the motherboard and gently sliding your thumb upwards on the slot where the cable meets the motherboard. This will raise a very small clip that locks the cable in place.
The back panel is now free from the rest of the device.
Using tweezers, pull out the wire attaching the front panel to the motherboard.
12 farklı kişi bu kılavuzu tamamladı.
