Ana içeriğe geç
Giriş
Use this guide to access and replace the speaker. The creators of this guide could not get the speaker back in how it was originally, but the screw can hold it in place and the back panel can still close.
Parçalar
Hiçbir parça belirtilmedi.
  1. Lift the rubber flap covering the input/output jacks.
    • Lift the rubber flap covering the input/output jacks.
  2. Using a Phillips #0, remove the single 3.4 mm screw.
    • Using a Phillips #0, remove the single 3.4 mm screw.
  3. This step will permanently erase all user settings.
    • This step will permanently erase all user settings.
    • The memory battery can now be easily slid out of place.
    • If you are following this guide in an effort to perform a hard reset, you should now press the shutter button multiple times in order to drain any left over power, then replace the batteries and power the device back on. You have just performed a hard reset!
  4. Peel back the rubber cover above the in/out ports to reveal two screw heads.
    • Peel back the rubber cover above the in/out ports to reveal two screw heads.
  5. Remove both 5.4 mm screws using a Phillips #0.
    • Remove both 5.4 mm screws using a Phillips #0.
  6. Lift the in/out port plastic covering from the bottom where the backup battery used to be.
    • Lift the in/out port plastic covering from the bottom where the backup battery used to be.
  7. Remove each 6.3 mm screw on either side of the viewfinder using a Phillips #0 screwdriver.
    • Remove each 6.3 mm screw on either side of the viewfinder using a Phillips #0 screwdriver.
  8. Remove the three 4.8 mm screws on the bottom of the back plate using a Phillips #0.
    • Remove the three 4.8 mm screws on the bottom of the back plate using a Phillips #0.
  9. Peel back the rubber covering next to the menu dial to access the screw.
    • Peel back the rubber covering next to the menu dial to access the screw.
    • Remove the single 3.4 mm screw using a Phillips #0.
  10. The back panel can now fall off easily by turning the device upside down. Be sure to catch it so the data ribbons do not tear or tug.
    • The back panel can now fall off easily by turning the device upside down. Be sure to catch it so the data ribbons do not tear or tug.
  11. Remove each data ribbon cable from the motherboard by applying pressure down towards the motherboard and gently sliding your thumb upwards on the slot where the cable meets the motherboard. This will raise a very small clip that locks the cable in place.
    • Remove each data ribbon cable from the motherboard by applying pressure down towards the motherboard and gently sliding your thumb upwards on the slot where the cable meets the motherboard. This will raise a very small clip that locks the cable in place.
    • The back panel is now free from the rest of the device.
  12. Remove each of the 3.4 mm screws holding in the LCD using a Phillips #0. Remove each of the 3.4 mm screws holding in the LCD using a Phillips #0. Remove each of the 3.4 mm screws holding in the LCD using a Phillips #0.
    • Remove each of the 3.4 mm screws holding in the LCD using a Phillips #0.
  13. Grip the wire attaching the speaker to the data ribbon cable and pull it out.
    • Grip the wire attaching the speaker to the data ribbon cable and pull it out.
    • The LCD is now free from the back panel.
  14. Remove the single 4.8 mm screw using a Phillips #0.
    • Remove the single 4.8 mm screw using a Phillips #0.
  15. Remove the speaker by firmly gripping the top of the speaker and pulling down towards the bottom of the back panel while rotating the top of the speaker upwards, away from the back panel. This will allow the speaker to come off of its pivot point.
    • Remove the speaker by firmly gripping the top of the speaker and pulling down towards the bottom of the back panel while rotating the top of the speaker upwards, away from the back panel. This will allow the speaker to come off of its pivot point.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Mike Seed
2.631 İtibar
8 adet Kılavuz yazıldı
Takım
USF Tampa, Team 1-6, Hickman Fall 2014 USF Tampa, Team 1-6, Hickman Fall 2014 üyesi
USFT-HICKMAN-F14S1G6
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 8
Her zaman: 1,391
