Ana içeriğe geç
Canon EOS 5D Mark II Rear Button Contact Replacement
Neye ihtiyacın var
    1. Canon EOS 5D Mark II Rear Button Contact Replacement, Back Panel: adım 1, 1 resimden 1.
      • Peel back the rubber cover above the in/out ports to reveal two screw heads.
      FixBot'a Sor
      Yorum Ekle
    2. Canon EOS 5D Mark II Rear Button Contact Replacement: adım 2, 1 resimden 1.
      • Remove both 5.4 mm screws using a Phillips #0.
      FixBot'a Sor
      Yorum Ekle
    3. Canon EOS 5D Mark II Rear Button Contact Replacement: adım 3, 1 resimden 1.
      • Lift the in/out port plastic covering from the bottom where the backup battery used to be.
      FixBot'a Sor
      Yorum Ekle
    4. Canon EOS 5D Mark II Rear Button Contact Replacement: adım 4, 1 resimden 1.
      • Remove each 6.3 mm screw on either side of the viewfinder using a Phillips #0 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    5. Canon EOS 5D Mark II Rear Button Contact Replacement: adım 5, 1 resimden 1.
      • Remove the three 4.8 mm screws on the bottom of the back plate using a Phillips #0.
      FixBot'a Sor
      Yorum Ekle
    6. Canon EOS 5D Mark II Rear Button Contact Replacement: adım 6, 1 resimden 1.
      • Peel back the rubber covering next to the menu dial to access the screw.
      • Remove the single 3.4 mm screw using a Phillips #0.
      FixBot'a Sor
      Yorum Ekle
    7. Canon EOS 5D Mark II Rear Button Contact Replacement: adım 7, 1 resimden 1.
      • The back panel can now fall off easily by turning the device upside down. Be sure to catch it so the data ribbons do not tear or tug.
      FixBot'a Sor
      Yorum Ekle
    8. Canon EOS 5D Mark II Rear Button Contact Replacement: adım 8, 1 resimden 1.
      • Remove each data ribbon cable from the motherboard by applying pressure down towards the motherboard and gently sliding your thumb upwards on the slot where the cable meets the motherboard. This will raise a very small clip that locks the cable in place.
      • The back panel is now free from the rest of the device.
      FixBot'a Sor
      Yorum Ekle
    1. Canon EOS 5D Mark II Rear Button Contact Replacement, Rear Button Contact: adım 9, 2 resimden 1. Canon EOS 5D Mark II Rear Button Contact Replacement, Rear Button Contact: adım 9, 2 resimden 2.
      • Remove each of the four 4.8 mm screws holding the protective plate over the button contact ribbon cable.
      FixBot'a Sor
      Yorum Ekle
    2. Canon EOS 5D Mark II Rear Button Contact Replacement: adım 10, 2 resimden 1. Canon EOS 5D Mark II Rear Button Contact Replacement: adım 10, 2 resimden 2.
      • Free the blue data ribbon cable by firmly pressing your thumb over the black clasp at the end of the cable and sliding your thumb to the left. This will raise the clasp and free the cable.
      FixBot'a Sor
      Yorum Ekle
    3. Canon EOS 5D Mark II Rear Button Contact Replacement: adım 11, 1 resimden 1.
      • Pull back the rubber backing found underneath the blue ribbon cable.
      FixBot'a Sor
      Yorum Ekle
    4. Canon EOS 5D Mark II Rear Button Contact Replacement: adım 12, 1 resimden 1.
      • You can now use a brush to clean any built up residue beneath the buttons.
      FixBot'a Sor
      Yorum Ekle
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Mike Seed
3.166 İtibar
8 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-6, Hickman Fall 2014 USF Tampa, Team 1-6, Hickman Fall 2014 üyesi
USFT-HICKMAN-F14S1G6
3 Üyeler
17 adet Kılavuz yazıldı
2Kılavuz Yorumları
Thank you for the great guide. Can you include one more step on the circular button as well? It will complete the guide by covering all the buttons in the back.
Also, do you have a recommendation on where to get a replacement button? My button is sticky.
Dat Chu - Yanıt Paylaş
My 5D Mark II buttons work fine in auto mode, but don’t function in other modes. IE Manual, AV, TV ETC. Do you think this is a button residue issue? My camera may have taken on some water during my last shoot. What fix would you suggest?
Brian Kingsberry - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 12
Son 30 gün: 48
Her zaman: 6,982
