Giriş
This guide will show users how to replace the top panel and access many internal parts such as the viewfinder and shutter assembly.
Neye ihtiyacın var
Peel back the rubber cover above the in/out ports to reveal two screw heads.
Remove each data ribbon cable from the motherboard by applying pressure down towards the motherboard and gently sliding your thumb upwards on the slot where the cable meets the motherboard. This will raise a very small clip that locks the cable in place.
The back panel is now free from the rest of the device.
Using tweezers, pull out the wire attaching the front panel to the motherboard.
Remove the single 5.9 mm screw next to the the strap loop on the same side as the shutter button.
14 farklı kişi bu kılavuzu tamamladı.
13 Yorum
Everything it's very nice in this guide.
I just have a question?
Where do I can find the top panel to buy it?
It's seem almost impossible...
I would also like to know where a replacement top panel can be purchased from.
I purchased one on Ebay , (US) $100 USD
