Ana içeriğe geç
Canon EOS 60D: Replacing Eye piece and Battery door
  1. Canon EOS 60D: Replacing Eye piece and Battery door, Eye piece and Battery door: adım 1, 2 resimden 1. Canon EOS 60D: Replacing Eye piece and Battery door, Eye piece and Battery door: adım 1, 2 resimden 2.
    • Removing the eyepiece is easy. There are two methods, you can do it yourself, or put it in your camera bag a dozen times and at least once, it will fall off.
    • Grip the eyepiece by the sides firmly (index finger and thumb). Wiggle it upwards until it is off.
  2. Canon EOS 60D: Replacing Eye piece and Battery door: adım 2, 2 resimden 1. Canon EOS 60D: Replacing Eye piece and Battery door: adım 2, 2 resimden 2.
    • Open the battery door
    • Rotate the door so the one side of the hinge pops out (see photo #2)
    • Slide other pin out (it pops out the same, but this is easier)
Sonuç
Rubber grips will require adhesive. (I havent gotten this far, I assume rubber cement / double stick tape may work)
4 farklı kişi bu kılavuzu tamamladı.
Eric D
1.284 İtibar
5 adet Kılavuz yazıldı
Bir Yorum
But how do you REPLACE the rubber eye piece? Mine seems to be NOT glued, but in a tract of sorts.
Wendell C Durnil - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 11
Her zaman: 5,907
