Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Use a thin piece of plastic, spudger, or fingernail (if you have them) to lift up the edge of the grip, and pull up slowly.
Repeat for the other two grips
Remove the adhesive like you would rubber cement, just rub your finger against it, it will come off.
Optionally throw the balled up adhesive at people pretending its a booger :)
Using a Spudger, fingernail, or other thin plastic tool to wedge the panel off of the camera
Start at the camera's front. Pulling on the rubber av-cover may be enough to get it to move off the body
Only pull about 1/4" (3-5mm). There is a tab that will need to slide out
At this point, the only thing holding on is the dust-cover is hooked onto the front panel
Slide down to remove without damaging the cover. (see photo with cover removed)
You can see how the cover, and side piece fit together in the second image.
7 farklı kişi bu kılavuzu tamamladı.
