Ana içeriğe geç
Canon EOS 60D Rear Cover Removal
Neye ihtiyacın var
  1. Canon EOS 60D Rear Cover Removal, Rear LCD Screen Dissasembly: adım 1, 1 resimden 1.
    • Take the LCD out of its place to expose the Phillips #PH00 screws.
    • Remove the two 2.5 mm Phillips #PH00 black screws on both sides of the LCD screen.
    • Next remove the two 3 mm Phillips #PH00 black screws near both sides of the base where the screen swivels.
  2. Canon EOS 60D Rear Cover Removal: adım 2, 1 resimden 1.
    • Using a plastic opening tool, carefully pry off the back cover of the LCD.
  3. Canon EOS 60D Rear Cover Removal: adım 3, 2 resimden 1. Canon EOS 60D Rear Cover Removal: adım 3, 2 resimden 2.
    • Remove the 3 mm Phillips #PH00 silver screw on the side of the screen.
    • Turn the screen to remove the second 3 mm Phillips #PH00 silver screw.
  4. Canon EOS 60D Rear Cover Removal: adım 4, 1 resimden 1.
    Bu adımda kullanılan alet:
    Satın Al
    • Using the tweezers, carefully disconnect the rear connector by pulling it away from the screen.
  5. Canon EOS 60D Rear Cover Removal, Removing Rear Cover: adım 5, 2 resimden 1. Canon EOS 60D Rear Cover Removal, Removing Rear Cover: adım 5, 2 resimden 2.
    • Now, four 2.2 mm Phillips #PH00 screws holding a cover around the hinge should be visible.
    • Turn the swivel around to expose the remaining of the aforementioned screws.
    • Then use the PH00 screw driver to remove them.
  6. Canon EOS 60D Rear Cover Removal: adım 6, 2 resimden 1. Canon EOS 60D Rear Cover Removal: adım 6, 2 resimden 2.
    • The eye piece will slide right off with a firm push upwards.
    • Remove the 3.4 mm Phillips #PH00 screw using a PH00 screw driver.
    • Remove the two 9.9 mm Phillips #PH00 screws using the PH00 screwdriver.
  7. Canon EOS 60D Rear Cover Removal: adım 7, 1 resimden 1.
    • Using the PH00 screwdriver, remove the 3.8 mm Phillips #PH00 screw located on the back of the camera.
  8. Canon EOS 60D Rear Cover Removal: adım 8, 2 resimden 1. Canon EOS 60D Rear Cover Removal: adım 8, 2 resimden 2.
    • Using the plastic opening tool, carefully pull up the rubber grip around the port side of the camera.
    • Remove the four different sized screws located beneath the rubber grip.
    • 6 mm Phillips #PH00 screw.
    • 3.4 mm Phillips #PH00 screw.
    • 3.9 mm Phillips #PH00 screw.
    • 2.2 mm Phillips #PH00 screw.
  9. Canon EOS 60D Rear Cover Removal: adım 9, 2 resimden 1. Canon EOS 60D Rear Cover Removal: adım 9, 2 resimden 2.
    • Using the plastic opening tool, carefully pry off the the side cover.
  10. Canon EOS 60D Rear Cover Removal: adım 10, 1 resimden 1.
    • Remove two 4.8 mm Phillips #PH00 screws from the memory card side of camera using the PH00 screwdriver.
  11. Canon EOS 60D Rear Cover Removal: adım 11, 1 resimden 1.
    • Look at the bottom of the camera so the serial number tag reads up right.
    • Using the PH00 screw driver, remove the top three 3.5 mm Phillips #PH00 screws.
  12. Canon EOS 60D Rear Cover Removal: adım 12, 1 resimden 1.
    • Now gently pull the back cover off the camera.
    • Gently pull the orange wire connected to the motherboard of the camera up and off of the motherboard.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Tyler Vaal
695 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 16-6, Wollert Fall 2015 USF Tampa, Team 16-6, Wollert Fall 2015 üyesi
USFT-WOLLERT-F15S16G6
3 Üyeler
14 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 21
Her zaman: 2,411
